check your LR bite. You might have to much. Check all your wheel weights. I had same problem and found my wheel weights were off. to much LR and lost LF weight.
What Would Cause a Car to do This?
I am unable to check the chain right now (car is on jackstands waiting for a lower contol arm) but I will check it. There was a little more grip this week but I was able to keep it down on tackier tracks before. Thanks for the chain idea I never thought of it stretching. Do you have to replace them often or just keep shortening it? ~Thanks~Originally posted by jedclampit View PostDid your chain stretch?
Is there more grip in the track?
I did not realize that LR bite would cause this. I have been going up small amounts on LR to fix my handeling problems and this was the one that was supposed to fix all (losen entry/tighten middle-exit). It was not losening entry early in the night enough so I moved the RRU bar down 1 hole last week and went up alittle more on LR and it was much better in. From the begining of the year til now I have gone up 20# of LR and the LF-RF split has gone from around 85# to 60#. I think I can go back to about 125# LR now with the RRU bar move to fix entry, but what is the best way to fix what I will give up on middle and exit? The way I see it on the GRT adjustment guide would be to raise the LRU bar. Also would moving the 5th coil towards the front of the car help keep the LF down? Mine is at 32" and GRT recomends 36" (1/4 mile with what I would call a medium banking) Thanks for the input.Originally posted by fletch lives View Postcheck your LR bite. You might have to much. Check all your wheel weights. I had same problem and found my wheel weights were off. to much LR and lost LF weight.
What does everybody think about this idea?
Everybody on here has good points. But it cant hurt to just throw it on scales and double check your weights. especially since you said you kept putting more LR in it to free up entry. Something might have loosened up and coilover might have backed off or something somewhere else. You can flatten J-bar a little to free entry or even soften up LF spring a little to free entry instead of keep jacking LR into it
Good point but I always scale the car every week just to make sure nothing like that has happenned. The numbers I stated came from my weekly setup sheets. ~Thanks~Originally posted by fletch lives View PostEverybody on here has good points. But it cant hurt to just throw it on scales and double check your weights. especially since you said you kept putting more LR in it to free up entry. Something might have loosened up and coilover might have backed off or something somewhere else. You can flatten J-bar a little to free entry or even soften up LF spring a little to free entry instead of keep jacking LR into it
With regard to checking for binds, this is how I do it.
Rear:
Remove shocks and springs. Put jack under center section of rear-end. Move rear end through range of motion (should be like a seesaw on the jack) and check 4-bars on each side to make sure they rotate freely through all points of the range of motion of the rear-end. Do the same check for the j-bar through all points of the range of motion of the rear-end. Also through all points of the range of motion of the rear-end, make sure the drive shaft rotates freely and does not bind or bottom out in the transmission tail housing.
Put shocks back on car and check to make sure that the shocks all spin freely though the rear-end's range of motion
Front:
Remove shocks and springs. Move RF spindle up and down through full range of motion. Keep moving it up and down rapidly while someone else turns the steering wheel through its full range of motion. Repeat that process for the LF. Put shocks back on car and check to make sure that the shocs spin freely though each sides range of motion (steering won't affect this so no need to steer it on this part).
Hope that helps.
Remove
You were right...chain stretched. Top bar angle was at 51 degrees...shortened it 1 link and and bar angle is back to 44 degrees. I left my %'s where they were and kept 140# LR just to see if it was the chain. ~Thanks~Originally posted by jedclampit View PostDid your chain stretch?
Your welcome brother, wish they were all that easy a fix!
Bet you start measuring that every week now!
i would just suggest you that better you take your car to garage andc have its check up with good mechanic as this would be better option for you
Update and another question.
Car was still a little crazy acting and pulling the left front in the heat so I decided to move the fifth coil towards the front of the car. I wanted to move it 2" but that hole was messed up so I went 3" and the car seemed to calm down and I didn't notice it pulling the LF but it was a 4" cushion(curb) and it was a wild night running up there. The car was fast and I went from a 12th starting spot to 5th before jumping the cushion real bad and getting thrown off the track with a hard right turn...lol...but it was exciting. The car was still unpredictable. .. Which leads me to my new question...
Today it was time for a bolt check and I found the upper left rear bar had issues. The bolt was tight but it spun real easy like it was loose. I have 3 slots on the birdcage that I can use and each slot has 3 vertical location to mount the bar. What had happened is the bolt had chewed up the birdcage and had worn out the seperation for the vertical mounting and was allowing the bar to ride up and down on the birdcage.
1) What would this do to the handeling of the car?
2) Which slot should I move it to? (towards the front or back of the car)
3) Where in the slot (up/middle/bottom) of the slot should I put the bar?
I chose to use the back slot and used the high position(furthest from rearend). My thought for the hight was to help take bar angle out to help keep left front down(correct?) but I don't really know benefits of front to back slot choice.
~Thanks Again~
Listing approximate bar lengths for each location on the birdcage would be easier for people to provide help. You did change your bar length for your left upper rod, correct?
No I did not for a couple of reasons...Originally posted by charcoal01 View PostListing approximate bar lengths for each location on the birdcage would be easier for people to provide help. You did change your bar length for your left upper rod, correct?
1) I didn't know if I had to
2) The location I put it in now is the one Joe Garrison said to put it in when I talked to him over the winter. The reason I did not put it there is because it did not look like it had ever been used on this car so I used the one they had been using.
3) I was hoping I would get an answer on here before I did my final setup for this weekend.
4) The bar lengths I am using now are the ones that Joe gave me when I talked to him so I thought I might try it.
I will post bar lenghts later ~Thanks~
