Anybody have any suggestions. Car has been checked over and shocks dynoed but having traction problems. Does anyone know if this is a problem with afco silver series gas shocks. Dry track. Lf60psi rf40psi lr120psi rr 40psi. Thanks
Afco shocks ?
i think i would run the 90 psi in the LR behind shock and the 120psi in the LR traction shock. and you can go higher with them pressures but ive never been over 100psi on LR behind shock, and sometimes go up to 180 psi on traction shock
If you're running a high compression gas shock in front, disconnect before scaling. It will give false bite numbers.
