carb question
  • 1Mower
    • Jan 2008
    • 195
    carb question
    what size cfm gas carb do most motor builders use on 800 hp motors?
  • racin6mod
    • 2172
    I wish that I had 800HP to know the answer.
    • hucktyson
      • 1903
      Engine builders love to put 1.59 Venturi stuff on to
      Make big dyno numbers but for something that starts and races well you should have something between a 1.410 and a 1.460
      • sj valley dave
        • 1016
        We have 800hp+ and have a 1.59 Braswell, but only use it on big momentum tracks...Most of the time we run a Willy's 750 for crisper low end response...
        • hucktyson
          • 1903
          There it is ..... You found a way to mention your 800 hp ....
          • perfconn
            • 3636
            How much hp you have is not a good way to size a carburetor.Much more important is cubic inch and rpm intended.Formula for size is cubic inches divided by two times max rpm divided by 1728
            • 50j
              • 1047
              Advertised cfm isn't a good way to choose one. Measurements and knowing what works for the application is the best way.
              • hall99
                • 421
                We run a BD1010 Headed 430 most of the time 98% of the time I use a KB 650 carb on it. The motor loves it I guess because it speeds and sharpens the air flow.
                  Totally agree that cubes and RPM is the correct way to determine carb size. That being said, let's not forget about volumetric efficiency. I'd be interested in knowing if anybody had some numbers on VE for their engines and would be willing to share.
