what size cfm gas carb do most motor builders use on 800 hp motors?
carb question
We have 800hp+ and have a 1.59 Braswell, but only use it on big momentum tracks...Most of the time we run a Willy's 750 for crisper low end response...
Totally agree that cubes and RPM is the correct way to determine carb size. That being said, let's not forget about volumetric efficiency. I'd be interested in knowing if anybody had some numbers on VE for their engines and would be willing to share.Originally posted by perfconn View PostHow much hp you have is not a good way to size a carburetor.Much more important is cubic inch and rpm intended.Formula for size is cubic inches divided by two times max rpm divided by 1728
