The tire contact patch feels one thing and that is wheel rate.
The only "leverage" that the chassis has is dependent upon the VCG and the roll center and that is not influenced AT ALL by the upper shock mount on an A-arm suspension. PERIOD.
On an A-arm suspension, the only thing you can do with shock mounting is influence the wheel rate by changing the angle or the motion ratio (and motion ratio is only changed by moving the LOWER shock mount). You cannot change the roll center. Mount the top of the shock 10 feet in the air and the roll center of the car doesn't change. The wheel rate will be the same, therefore the handling will be the same.
For an A-arm suspension:
wheel rate=(motion ratio)squared times spring rate times the cosine of the shock angle.
Motion ration is the distance between the lower shock mount and the inner lower control arm mount divided by the distance between the lower ball joint and the inner control arm mount.
And by "shock angle" we're talking about the angle between the line that the shock travels and a line perpendicular to the ground.
Hint for those that don't follow the math: motion ratio is WAY more critical to wheel rate than shock angle.
Weight transfer calculation is more complex but with respect to the car itself, it only involves VCG and roll center. On an A-arm suspension, neither of these are influenced by shock mounting position.
If anyone would like to dispute these facts, I look forward to seeing the math that explains it.
