Using alcohol vs gas
  • W2racing
    • Dec 2010
    • 53
    Is it feasible to use a mechanical fuel pump for alcohol on 600-650 hp or is it best to use a belt drive pump? I have seen mechanical pumps listed for alcohol, but my friends who run late model say a mechanical pump doesn't really work very well. If you would use a mechanical pump, which pump/brand would you use?
  • gangster49
    • Oct 2008
    • 192
    We tried using a Pro-Cam mechanical pump for alcohol on our modified last season. After trying 3 different regulators we still couldnt make it work right. Switched to a belt drive pump and everything was good
    • lovinlatemodels
      • 486
      Yes you can with the Pro Cam make sure you have a #10 feeding the pump and #8 from pump to carb. We always used a #6 return to the tank with a Barry Grant regulator between the carb and return line to tank. Carried 3 to 4 lbs at idle and never had any problems holding 8 to 10 lbs at the end of the straight.
      • W2racing
        • Dec 2010
        • 53
        Thanks for the info. Which version of Pro Cam pump did you use? 11 or 15 psi pump?
        • racer1355inpa
          • 562
          I sold a customer a CV Products Billet mechanical fuel pump for alcohol. Bulletproof for 3 years and counting. We replaced the diaphragm assembly one time. A little expensive but worth it imo.
          • lmdriver72
            • Jul 2013
            • 17
            We're on a Holley diaphragm pump I believe part number 12 dash 327 get the one for alcohol don't need a regulator runs about 8 to 9 psi at idle and doesn't give up at the end of the straight. I like them because there's no regulator or return line. Had problems with both in the past. just two less things to go wrong
