Is it feasible to use a mechanical fuel pump for alcohol on 600-650 hp or is it best to use a belt drive pump? I have seen mechanical pumps listed for alcohol, but my friends who run late model say a mechanical pump doesn't really work very well. If you would use a mechanical pump, which pump/brand would you use?
Using alcohol vs gas
We tried using a Pro-Cam mechanical pump for alcohol on our modified last season. After trying 3 different regulators we still couldnt make it work right. Switched to a belt drive pump and everything was good
Yes you can with the Pro Cam make sure you have a #10 feeding the pump and #8 from pump to carb. We always used a #6 return to the tank with a Barry Grant regulator between the carb and return line to tank. Carried 3 to 4 lbs at idle and never had any problems holding 8 to 10 lbs at the end of the straight.Last edited by lovinlatemodels; 04-20-2014, 04:26 PM.
Thanks for the info. Which version of Pro Cam pump did you use? 11 or 15 psi pump?Originally posted by lovinlatemodels View PostYes you can with the Pro Cam make sure you have a #10 feeding the pump and #8 from pump to carb. We always used a #6 return to the tank with a Barry Grant regulator between the carb and return line to tank. Carried 3 to 4 lbs at idle and never had any problems holding 8 to 10 lbs at the end of the straight.
I sold a customer a CV Products Billet mechanical fuel pump for alcohol. Bulletproof for 3 years and counting. We replaced the diaphragm assembly one time. A little expensive but worth it imo.
We're on a Holley diaphragm pump I believe part number 12 dash 327 get the one for alcohol don't need a regulator runs about 8 to 9 psi at idle and doesn't give up at the end of the straight. I like them because there's no regulator or return line. Had problems with both in the past. just two less things to go wrong
