Caster and Camber Gain different scenarios?...
  • DirtRacer9x
    • Jul 2014
    • 305
    Hike vs camber gain
    Caster gain is a topic you're not going to get a lot of people talking about on here.
    Camber gain: Because of the huge amount of body roll the cars have today, you need camber gain (relative to the chassis as if it were sitting at ride height) to achieve the desired amount of camber relative to the race track itself.
    There's more to it than that (some of which I'm sure I don't yet understand) but that's the basics of it.
    • grt74
      • Jul 2009
      • 1380
      the entire front end of a race car has a ton of compromises,with that said camber is where you want the least compromise,caster gain or anti dive as some may call it,to me its all about how the driver drives(if he hits the brakes hard or he's really good at rolling in the corner off the gas)
      its something that you'll have to play with,not everyone drives the same,most people don't understand anti dive and if you don't,don't mess with it,your chassis manufacture should have this figured out,it will make your car act very silly if you go out of the good area on this adjustment
      • grt74
        • Jul 2009
        • 1380
        Originally posted by dirtracer9x
        well here's what i'm trying to understand. I'm not a gurue on it but my understanding is with chassis roll you want camber gain because of this. Now what i'm thinking is when a car isn't hiked and then does hike over that camber gain is needed. Now lets say i have a car that never comes off the bars and runs 2 brake floaters. Like i said i'm not a gurue on this but if i am never off the bars while at speed do i want camber gain? Maybe i have this all wrong but this is how i picture cars having camber gain and why they do. Most cars have one brake floater and the cars come off of the bars that i see but 2 brake floater cars don't as much as long as you're on brake or gas constantly keeping the chassis loaded. Am i close at all? Thank you for your input.
        you want your camber gain to be what ever the car wants,and this is very dependant on all your angles and lengths of your uppers and lowers
        • grt74
          • Jul 2009
          • 1380
          Originally posted by DirtRacer9x
          So can putting longer uppers on help the rf with camber gain? Since it would never be off the bars at speed on track? Is this too technical? I'd like to just know every possible option and its pros and cons.
          a longer upper will take away camber gain,a shorter one will add camber gain,also you would be surprised what an 1/8" shim in or out will do it doesn't take much if your close,its all about reading your tires
          • Bubstr
            • 3734
            What dynamic camber (with gain) should we shoot for? I was always told 1 to 2 degrees of negative on the RF, but seeing these club 29 cars, it appears to be much more.
            • grt74
              • Jul 2009
              • 1380
              there good cars but they don't win them all
              • grt74
                • Jul 2009
                • 1380
                So are there situations like the one I described why camber gain is desired or not desired?
                if your using the whole tire its just plain old common sense its going to be faster on the stop watch,yes there are times that tire scrub will help and thats what club 29 is doing
                tire sidewall deflection has a factor in this also
                • grt74
                  • Jul 2009
                  • 1380
                  I'm just trying to figure out why we have camber gain exactly. Like why chassis builders built this into their cars. This will help me find my answer I believe.
                  last answer for me,you need camber gain because your trying to keep the contact patch of your tire flat to the track(so it uses the whole tire and not just the edges,inside or outside)there are however several ways to do this and some are better than others,remember like i said above,tire deflection(sidewalls or how the sidewalls are built)has a factor in this also
                  • fastford
                    • 4059
                    get you a pyrometer and go to testing, that's what I do.
                      So camber gain has to do with only tire deflection and chassis roll or a combo of both? What's optimal and why? 1-2* 2-3* and why? Thanks
                      Both effect how your contact path comes into contact with the track. So both matter. There are situations where more camber gain than optimal can help too. (See Club 29)
                      You cannot just "figure" a correct answer. You have to test and learn. That is what even the guys who seem to have all the answers are doing.
                      • 7uptruckracer
                        Caster Gain is not anti or pro-dive at all. Has nothing to do with wheel loadings as a result of braking forces like anti- and pro- dive do. Caster gain is an area that isn't going to be talked about much its in your spindle design as well as your arm arrangements most try to minimize dynamic caster gain split, BUT you can use caster numbers these days to also effect your camber curves where you normally lose camber in chassis ROLL you can negate the effect with caster gain or untraditional caster numbers. We are using caster on asphalt that will blow your mind like +8-10 on both sides so as you turn the wheel you also change wedge in the car as well as negate LF positive camber loss through dive and you can use it to help roll loss. On the RF you can keep it from going through to much camber transition depending on if your running a tie down setup or one that travels. Look at which setup you run if your tied down you might start with less static on a short RF upper and gain a lot. Or if you don't you could run a longer arm on higher static. Some use the camber thrust theory and some like to utilize the contact patch which seems to be seen less and less. Look at the cup guys they use camber thrust this is why they always blow tires they are running them on the edges its like leaning on a broom stick thats standing straight up you will fall over now kick the handle out and lean on it and you can lean harder because its helping hold you up
                        • Brian Gray
                          • Feb 2012
                          • 1102
                          Just keep in mind camber thrust is a dynamic force so if you are loading a tire to gain traction the camber thrust can easily over load the tire and cause you to loose traction on that tire. Facts are there are no right or wrong answers it all depends on what you need out of your setup.
                          Shocks by BGR army
                          • drtrkr244
                            • 1024
                            Unfortunately, all of these handling concepts, leaves you at the mercy of your tire compound/construction. Theres no technical info available from the Purple beast. They treat you like a spy when you ask for it and then only give vague answers, that you knew already. Only Professor Furney has ever published any such info, but it was only on D-xx compounds. Hoosier wouldn't supply any help to him even though he was trying to help the local racer.
                            This is why your local hotshoe cant compete when the national boys come to town. They think they should make their normal chassis adjustments but the different compounds don't respond like their Saturday nite ones do. The touring guys know what compound to run based on the track conditions and their previous experience.
                            • Brian Gray
                              • Feb 2012
                              • 1102
                              All you gotta do is cut them apart. The compound bases you will never really know because its always changing depending on what materials are cost effective at the time. But as far as tread belt and sidewall construction all you gotta do is cut them up. You can plainly see the stiffeners and location. That's ultimately what is important.
                              Shocks by BGR army
