Originally posted by 7uptruckracer
View Post
Caster and Camber Gain different scenarios?...
im not saying I'm right or wrong but i do know this for a fact and if you don't believe me try it on a car,if your lower and your upper are at the same angles,you'll have zero caster gain from o to 3" up and down,the only way to add caster gain is with anti dive,yes you'll set your static settings but if there isn't any anti dive it won't change from 0 to 3",yes there is different spindle inclinations but thats another story altogether,Last edited by grt74; 09-14-2014, 02:19 AM.
You can have caster gain/loss without anti-dive. The arch of the lower control arm can move fore and aft the chassis by the strut rod or 2nd piece of the lower if those archs are different.Generally you are correct that anti dive is what causes caster gain/loss because it changes the arch of the outer ball joint fore and aft compared to the lower ball joints arch.I know some change the front mounted strut rod on the rocket to the rear so it doesn't drag and by doing this you change which direction that arch moves. Instead of pulling the lower forward in compression causing gain it then pulls it backwards causing a caster loss.BUCKLE UP NOW, YA HEAR?
there is a lot to todays front ends,the best thing to do is just keep good notes and try different things,if they don't work go back to what you had,moyer said it best for every 50 things you try 1 or 2 may workOriginally posted by DirtRacer9xI'm officially lost haha. But I like reading the input guys. :cheers:
Simple answer is, with more caster you get more or less tire loading when you turn the wheel.
When you want this is in the corner. The gain is made with dive and roll.
What it does when wheel turns right, it adds loading because the ark on the spindle drives the tire into the track and opposite for turning left. This also loads or unloads the LR.
So as you go threw the corner loose, you steer right and gain loading on RF and LR that tightens the car up. If your pushing, you automatically turn left, which unloads RF and LR helping to loosen the car up. It's built in chassis adjustment. While on the straits with out caster gain, it doesn't effect the loading as much, keeping your static rear loading for traction. It's not about where the weight is, but where it is transferred to.
This is nothing new, They where using it in the 50s on Midgets and Sprint Cars even the straight axle mods.
Your amount of camber gain is really dependent on how your car rolls.
If your roll center is further left, the entire front end will lower under body roll and will need less camber gain because there will be less camber loss as the body rolls.
If the roll center is closer to the center of the car or RF, the RF will loose camber more under body roll and will need more gain to keep the grip in the RF tire.
A good way to visualize the need for keeping camber in the RF is to take a tire and put your foot on the rim where it bolts to the hub.
Taking a little air out will make this more visual.
Push on the rim with your foot and you can see the outside of the tire is loaded more than the inside. The inside will actually unload to a point where there is no pressure on it at all.
Now, angle the top toward your leg and push on it again.
The inside of the tire will begin to load more and eventually equalize with the outside of the tire.
This is the reason to put gain or keep the camber consistent through body roll. Body roll will naturally want to take camber out. Gain will help keep camber consistent through body roll.
Camber thrust was mentioned earlier in this thread and this will really help turn the car. When stretched rubber will naturally want to return to it's relaxed state.
As the tire is stretched in a turn, and the tire is loaded properly, it will want to continuously 'snap' back into position and push the front end left.
The problem with tire temps is that when the slows or comes to a stop the temps will instantly begin to equalize across the tire.
Unless there is a huge problem tire temps will have a hard time picking it up. The indicator I like is tire wear.
Caster gain is another can of worms. I would recommend digging further into ackerman before caster gain. I think there is more speed to be had through ackerman adjustments than caster gain.
Good Luck,
KevinCheck out my book on Amazon.
My YouTube Channel
I believe you also have to know tire loading/tire heat gain to determine if you have the proper compound. I only know of one logarithm table that accurately predicts heat buildup. Unfortunately, it only applies to D-xx compounds.Originally posted by Brian Gray View PostAll you gotta do is cut them apart. The compound bases you will never really know because its always changing depending on what materials are cost effective at the time. But as far as tread belt and sidewall construction all you gotta do is cut them up. You can plainly see the stiffeners and location. That's ultimately what is important.
