Pinned down hard RF? Does this make it so you have no drive off or once completely tied down hard will it automatically make that point of the car a fixed pivot point for weight transfer rearward? Or, would a pop off or less rebound low speed be better? What's the difference because I've heard both being ran. Pro and Cons?
What's Better? RF Set Up and Drive
I'm really not being a wise guy here even though it may seem like it,what ever it takes for it to work for you,there isn't a perfect answer for this,ill bet there won't be a lot of direct answers on this,test,test,test,but you can achieve drive with the rf pinned down
Exactly what grt74 said. A racecar works as a package. If you just bolt on a RF with extreme rebound numbers and keep it pinned without changing anything else, you'll be wondering how a car could lose so much drive. It's all about finding what works together.
By gaining back the dynamic crossweight you just lost by traveling the RF farther and keeping it there. How do you do that? Like grt74 said, test, test, test. Pros, getting the nose down, butt up attitude in the car helps a lot of different things like weight transfer and aero. Cons, super rough tracks? LolOriginally posted by DirtRacer9x View PostOk so how can you achieve drive with RF pinned down? Pros and Cons over not being pinned.
You don't, its about momentum with the rf pinned over with rebound. Also just because its on the rf doesn't mean the rebound numbers are crazy high, soft spring with a bump or coil bound stack. Lots of options and no one is going to give you the direct answer to your question
So example. Lets say you're pinned on rf. are you heavily pinned on the high and low speed stuff or just the high speed and bleed off rf with low speed? I'm trying to understand exactly these 2 different ways to do things. I know I won't get an exact answer but when doing these different set ups will you have say the RF pinned more and loner on a sweeping track vs the track that has straight always? Is the car driven strictly off of cross out of the rf and LR hike when pinned that heavy? If someone can give scenarios as to what works better and why that would be great. Just opinions at the very least.
all i can say its going to be a ton of work,notes and testing is where its at,and saying that I'm learning more every day with different set ups,hell I've got 3 different rf shocks depending on what i want to do,if you quit hunting you'll find yourself in the rearLast edited by grt74; 10-02-2014, 11:13 PM.
You are thinking way to much. Your looking for a magic bullet . they don't exhist!
Some guys like the car pinned over why? Too many reasons. Same reason some dislike it.
Listen to the car and give it what it wants. That's the honest answer.
If you want just an opinion I like my car pinned over on the rf because it gives me a feeling of stability . it may be false and at times it hinders my performance . but I fee like the cat is easier to manipulate when it is steadied on the rf. That's why I prefer this set up. Its not for everyone though and its not always fastShocks by BGR army
I'm actually looking for a reasoning. My thinking is I'd possibly want to be tied down more on a continuos radius/arc track so the car steers more positive and maintains momentum. While a track like a paper clip I'd want that thing to release and drive off harder. This is what I'm trying to figure out.
DirtRacer9x-
I wouldn't look at it in the terms of sweeping vs. paper clip. I'd go by what I feel and what my crew chief tells me the car looks like from the middle of the turn onto the straight-a-way. I like the car laid over on the RF when I need to steer on entry to the middle usually slightly off of the throttle. When I'm ready to apply more throttle and exit, I want the RF to start rising back up to aid in forward drive. This is what works for me. We've had the RF laid over onto the straight and thought we were giving up forward drive on most nights. However, there are guys running the RF compressed all the way around the race track making good forward bite on all sorts of tracks.
Shocks, bumpstops, dual stage springs, bump stop shims all effect this. The "attitude" of the car and "timing" of these events that induce roll all play a part and thats what these guys are trying to point out. Another thing at play here is how compressed the RR is. That also helps make forward bite. Depending on what you have at the RR, you can load it greatly or not so much as you compress RF. That added to the other things you mentioned with LR hike, and cross all play a role.
Go find some pics/vids of Brandon Shepard. He runs a lot of RF pinned set ups.
There are other ways to help the RF steer better than pinning it over which involve front end geometry.
I can relate to your frustration, and the 4m tech board isn't what it once was. These cars are getting so competitive and the gains so small these days that those that are in the "know" and really understand whats going on aren't talking anymore. The cool part of that is, all that information can't be bought or gathered on some forum like this one. If you do your homework, teach yourself, and experiment, you can find gains that others don't know about.I like it that way because it rewards the guy who uses his brain, instead of the guy that uses his pocket book.Last edited by FlatTire; 10-03-2014, 05:28 PM.
