What is the difference in à Wissto smackdown and a regular smackdown?
Wissoto ?
I'm not 100% sure, but I thought the Wissota cars had more engine set-back. I guess it could be that they are a longer wheel base and the mid-plate is the same distance from the rear axle, thus giving more engine set-back? Hopefully somebody can give you an answer. Or you can always try your luck calling MasterSbilt. 812-793-3666
The front suspension mounts are 1" further forward than a non "W" car. This puts the engine at a 7" setback if installed in standard location.
