RF stack springs
  • jel
    • Nov 2008
    • 34
    RF stack springs
    If you want about 300 lb. RF with stack spring
    What combo is best and why
    625/575 = 299lbs.
    750/500 = 300 lbs.
    1000/425 = 298 lbs.
    all help would be appreciated thanks
    • 14304
    625/575 = 299lbs.
    750/500 = 300 lbs.
    1000/425 = 298 lbs.
    If you are stacking springs to make a single rate spring, it doesn't matter all that much. If one of them is only 4" long, I would make sure it was a relatively stiff one. Probably at least 600#.
    • DEKconsulting
      • Apr 2015
      • 234
      Why going with the stack if your only goin to 300
      • DEKconsulting
        • Apr 2015
        • 234
        Probably better with standard spring
        • DEKconsulting
          • Apr 2015
          • 234
          I tried a bunch of different combo best one i found was a 350 over a 700 which comes out to a 233
          • muddychevy98
            • 21
            I'm sure there isn't a real quick and simple answer but how do you get the final spring rate of stacked springs?
            • HuckleberryB4
              • 220
              Spring rate 1 x Spring rate 2.
              divided by
              Spring rate 1 + Spring rate 2.
              500 x 500 = 250,000
              500 + 500 = 1000
              250,000/1000 = 250 lbs stack rate.
              • rakracing
                • Dec 2014
                • 218
                I preferred the 400 over 500 with the travel stop at 1.25". have to play around with rebound to get the timing right, but it drives off great if ya get it right
