If you are running an undersling car, do you still need the Limiter Chain?
Left Rear Front Shock, Yes or No???
Basically the same thing, just different way to stop the rear-end. Just easier to adjust the chain then changing the under-sling as a stop unless your using an adjustable devise on the under-sling.Originally posted by redfred View PostIf you are running an undersling car, do you still need the Limiter Chain?
running the shock to the axle tube is like running the shock on a clamp bracket..some like it some dont(the clamp brkt)..i like the chain limiter and the shock on a clamp bracket(with a lot of gas pressure it seems more effective than on the birdcage/also adds more l.r. drop if you need it ) with minimal traction..im sure some will dissagree..jmo..windy..~V~..
