Rockets New Longhorn
    Originally posted by TALON75 View Post
    Capitol has had bolt on brackets for years, one thing Rumley actually copied .
    And it is the perfect way to sell your customers a car with different suspension than what you run.
    • TALON75
      • 887
      True, a few other benefits also. It will be the new norm I think.
      www.RACE91.com
      • talclipse
        • 738
        One would think it would be easy enough for these chassis manufacturer's to incorporate what is obviously a better design that would have minimal increase in material/ production costs, but my understanding is that these "new super high end" features are only available with the new car$.
        • Lizardracing
          • 839
          Ive seen bolt on brackets on the modifieds since at least 1990-93 era.
            Bolt-on vs. Weld-on anything is just a matter of making the chassis a bit more modular.
            With that being said, I really like the Longhorn J-bar mounting brackets. A hard hit to the wall in most cars results in bending the 2x2 and a significant amount of fab to get it redone right. It appears that this design would simply require replacing the plates.
            • Krooser
              • Nov 2012
              • 3117
              Is this now a Rockhorn? Longrock? Horny Rocket?
              Class of 2019
              • 25drtrkr
                • May 2015
                • 856
                Is that plate similar to what Lazer has been doing for several years now?
                  Not sure. Never been under a Lazer.
                  Check out https://www.youtube.com/watch?v=R8h0buM6_v8
                  At 0:28 you can see the mounts where the plates mount. Then at 1:43 you can see the brackets themselves in the background.
                  • 25drtrkr
                    • May 2015
                    • 856
                    The Lazer I saw at a PRI show a couple years ago, used an aluminum plate, with a series of holes, to use different lengths of j-bars. It was single shear. I like the idea of these bolt on brackets, makes it easier for repairs and testing new ideas.
                    • hanginitout
                      • 584
                      Originally posted by catgo22 View Post
                      Not smarta$$ questions. But I can't figure out what difference the tail section makes - all that behind the link brackets? All it does in my brain is hold the fuel cell and brace the rollbar. And moving the cage in - if you have to have ballast anyway, what difference does that make? I can see how the front geometry can make a difference. But all this other stuff seems like marketing to me.
                      IE Black,+ blue,+ orange+ and+ blue/grey and whatever other color = $$$$$$$$$$$$$$$$$
                      The Bible tells us to love our neighbors, and also are enemies; probably because they are generally the same people...
                      G.K. Chesterton
