Spring rubbers
  • Rocket0108
    • Apr 2008
    • 65
    Spring rubbers
    Ive started using spring rubbers on rr and rf any helpful ideas out there would greatly be appreciated.....like when and how to use them....i am starting with one on rf and adding as night goes on but not completely sure if thats right
  • RacerX10
    • 571
    That's the exact opposite of what I do
    I have a spring rubber in the RF and pull it out when it starts getting slick.
    • DEKconsulting
      • Apr 2015
      • 234
      I start with 4 rubbers in my rf and start taking out
      • RCJ
        • Nov 2007
        • 509
        If it works for you then it's right.As the track goes from tacky to slick we always tighten the car.On a conventional set up a spring rubber would accomplish this.I've never tried a spring rubber on a bump set up, but it should work the same as stiffening the main spring.The main benefit to spring rubbers would be they are a quick and effective adjustment.
        • DEKconsulting
          • Apr 2015
          • 234
          Do u r saying that im freein up by taking them out? If so u are still on the old school way of thinking my friend
          • Rayburnt1
            • 117
            DEK, do you feel the location or the rubbers or which one is removed first (top, bottom or middle) makes a difference or are they all the same reaction?
            • DEKconsulting
              • Apr 2015
              • 234
              I haven't tested that yet I've always started at the top and removed from there. But now I'm going to go to work tonite on the smasher
              • DEKconsulting
                • Apr 2015
                • 234
                I'll let u know my findings
                • DEKconsulting
                  • Apr 2015
                  • 234
                  Well did some testing last nite and it makes very little difference where u start taking or have ur rubbers placed. The difference is between 5 to 18 lbs
                  • Rayburnt1
                    • 117
                    DEK, thanks for the feed back
                    • CHUGG-A-LUG NUTZ
                      • Oct 2007
                      • 18
                      Would I soften the RR spring and then add spring rubbers to compensate? The spring rubbers that I have found are medium and hard compounds. Which one do you recommend? Thanks
                      • DEKconsulting
                        • Apr 2015
                        • 234
                        It all depends on what ur trying to achieve Chugg.
                        • zeroracing
                          • 1014
                          DEKconsulting, how are you keeping them in place, just zip tieing all around them? I had one shoot out in the shop on the spring machine, and even with 3 zip ties each they squirm, I am afraid during a race it may break some of the zip ties?
                          • RacerX10
                            • 571
                            Been running one on my RF for years .. never lost one. Did you get the right size for the coil distance ? It should fit fairly snug before you even get to the zip tie it in part.
                            • zeroracing
                              • 1014
                              Yeah I bought it sized for the spring, they fit snug, it's when you get multiple stacked up that touch it wants to kick one out. I have ran a single before without issue but seems the interaction between multiple... Did not know if I was overly worrying about them.
