Here's what I got 01 Rayburn have lf 550# spring rf 500# or 275 on swing arm RR is 325 on swing arm lift arm with 300# spring has j bar shocks are 1375 afco on front 1395 afco on rear 1373 on lift arm have standard Rayburn bar lengths left rear bar all way down right rear bar all way up weights are real close to right on per Rayburn don't have scale info in front of me have 6 inch bs wheels on rf and RR can go back to 5 on rf problem is carvis tight on entry can seem to make rotate from middle out it pushes like a freight train was told to increase rear stagger at 3 and 1/2 inches now its only 6 night I drove this car have ran decent in a older Rayburn that was 4 bar track is a 3/8 medium banked track usually dry slick any set up help would be helpful thanks
01 Rayburn on swing with lift arm
You could always increase left side percentage and remove lf spring.
I can't help but think something is bound up, front end settings are out of whack, or a brake issue such as larger pistons on right side of car. Those rear bar angles shouldn't work at all.Modern Day Spec Wedge Racing
Rf brake is shut off calipers are free and retract and are same size as lefts steering rack seems very firm maybe bad pump or rack thanks for any and all suggestions any one have a good set up
What if I were to put the 500 on rf and 450 on the lf and does any one have any set ups besides cj for a banked 3/8 track thanks in advance
If I remember right, Eldora's hot set up was 400 pound springs on all corners.I think there should be lifeguards in the genepool.
I've herd of the 400# springs all the way around also know a guy running a 900# RR spring on a Rayburn and he was fast
We always started square and just use bar adjustments to tighten. If all mounts are original I would do the following on spring rates:
LF 500 RF 525 (or 500 if you dont have a 525)
LR 275 RR 275 on Birdcage or 500 on swingarm
240 lbs LR
54.5% LS
56 - 57% rear
3.5" to 4" of stagger
Start LR bar 2 holes up from bottom
Start RR 1 hole up from bottom
If its tight on entry go down on LF spring rate at least 50 lbs
to tighten off the corner raise rr bar1 hole at a time, if car is coming off the corner straight & you just need more drive, start softening LR spring 200 usually works well on slick. Make sure to put wedge back to 240 when changing springs.
