brakes lockup
  • jarvis
    • May 2011
    • 16
    brakes lockup
    run a pure stock class rules say no after market master.Are running disk in rear but for the last three weeks calipers have locked up in the heat race have replaced everything front to back every week and we are not running a porpotion valve could that be it.It also always starts with the right rear
  • Egoracing
    • 4852
    Fluid has water in it or is cheap and it is swelling up/boiling and locking the brakes.
    • jarvis
      • May 2011
      • 16
      Ok I will use a better fluid.Could it be anything else
      • keithbaker
        • 121
        pinched line or calipers could be bad
        • racerkrp1
          • Aug 2007
          • 187
          Brakes
          Master cylinder not returning all the way back
          • stock car driver
            • 3233
            Usually when I have any rear brake issues its because the mounts arent 90 to the rotor, if one is bent just a tiny bit even it will apply side pressure to the caliper piston and the piston will not return into the caliper and THUS its locked up..
            I visually inspect my caliper mts every time I change gears, looking at the distance from the bolt to the rotor can be a good quick indicator also you can usually visually see a caliper that is not 90 to the rotor.
            • Chaps46
              • Mar 2009
              • 89
              Don't use DOT5!!
              • bushracing67
                • Oct 2007
                • 904
                Originally posted by Chaps46 View Post
                Don't use DOT5!!
                yeah i found that out this year, that (not a nice word)(not a nice word)(not a nice word)(not a nice word) sucks... the sticking brakes could be a bad rubber hose collapsing as well, check them all if your not running stainless hoses
                • jarvis
                  • May 2011
                  • 16
                  Started all over one more time new everything including brackets did use Prestone synthetic high heat fluid. Has anyone had any luck with it. Never the less I will let you
                  Know this weekend how it turns out thanks for the info guys
                  • dirty white boy
                    • 1238
                    seen this many times on stock lines..
                    white trash motorsports
                    • keithbaker
                      • 121
                      maybe check to see if your pedal and master cylinder is returning all the way
                      • Dirtrunner35
                        • May 2010
                        • 632
                        I have never seen a rubber brake hose collapse. It has always been where it is crimped together at the end to the metal. Rust forms under it, squeezing the hose shut.
                        • stock car driver
                          • 3233
                          I run DOT 4 fluid. Synthetic attracts and holds moisture, I wouldnt use it in a race car.
                          • Egoracing
                            • 4852
                            Synthetic is bad but ALL brake fluid will absorb and hold water. That is why on evey bottle it says only use fresh fluid. There are meters on the market that can read the water level.
                            • stock car driver
                              • 3233
                              YES true BUT synthetic is much worse at absorbing or attractiong the water from what I remember.
                              I havent read about it in years but I remember when the synth first came out everyone was getting soft pedals from it within a night or two.
