brakes lockup
  • gadirtracer
    • 1039
    #31
    Originally posted by jarvis View Post
    I ran all new lines from the master and I was told from the parts store the cylinder is from a 1968 truck and Im guessing it was disk all the way around since he said he is running the same set up but I did see my guy ran the lines on the master Front brake to front inlet on the master should the front be ran from the back side
    I would think about all trucks in '68 had drums, front & rear. Look into the master ports and see if there is a brass insert in either of the ports, if there is one, get a new 4 wheel disk master cylinder.
    If you are not wanting to purchase a new master cylinder yet, swap the front to the rear and rear to the front and see if the fronts lock up.
    I'd put a new 260-4893 Wilwood Master Cylinder and be done with it.
    Gill T. Azell
    • jarvis
      • May 2011
      • 16
      #32
      rules will not let me run a wilwood I am willing to buy a $ wheel disk brake one if someone tells me what I should buy earlier someone said mid 60s vette will it work or give me something you guys know for sure that works needs to be stock mount dual resivor and like I said the calipers and rotors are off the front of 84 grand prix shoul I change them to something differnt to
      • brummi5050
        • Nov 2010
        • 14
        #33
        Im getting ready to convert to rear disc myself. I was looking in a brake parts book at later model camaro master cylinders. Same MC for drum or disc. So im guessing they dont have residual valves in the MC. I have a 79 Buick regal and I will be checking for the same. I dont want to change the MC if I dont have to. Has anybody just tee'ed off of the front brake side for all 4 wheels? Just a thought.
        • keithbaker
          • 121
          #34
          We use a single reservoir master cylinder off a 65 chevy truck. Only has one line that comes out of it and we split it to 4 wheels, works pretty good.
          • cautrell05
            • 341
            #35
            For god sakes people never use a single piston master cylinder for all 4 brakes. Thats just stupid no matter how you look at it.
            There is no drum/ disk specific master cylinder. just different bore sizes. Find a book or somewhere that lists specs and bore sizes and pick from there. Your bore size is whats important. The original application dont mean squat.
            Nick
            • brummi5050
              • Nov 2010
              • 14
              #36
              Nick
              Wow thanks for the confidence! There are drum disc specific master cylinders according to the articles I have read. They have a residule valve built in the rear side, but thats probably stupid,too.LOL This is why people dont want to ask questions on sites. Didnt say im doing it, just asking if it will work. I thought if you use 1 for all, your braking would be even all the way around. My bad. Cant use racing MC or aftermarket proportioning valve either.
              • jarvis
                • May 2011
                • 16
                #37
                Alright guys this is what it did bought a 1960s manual master with disk all the way around it ran new steel lines from it to all 3 corners with stingray rotors and calipers off of the front of 84 grand prix.Now does it mater were the lines conect to the master as in front to the front port on the master or vice versa
                • cautrell05
                  • 341
                  #38
                  Not using a single master cylinder is about safety, plain and simple. You loose a hose with 1 single master cylinder and you loose all brakes. At least with a dual you will have some. Maybe not much but something at least.
                  In 18 years of turning wrenches professionally I have put alot pf mastercylinders on. Never once have I seen a built in valve on an older rear wheel drive application. Picking a master cylinder based off of application is not the best way to do it. It might get you close but your better off knowing exactly what your getting.
                  For example. 65 chevy c-10 is listed on rock auto as having a 1" or 1 1/8" master cylinder. -cast iron
                  75 camaro with power brakes 1 1/8 - cast iron
                  75 camaro with manual brakes 1" - cast iron
                  91 jeep wrangler 1" aluminum MC- looks just like the old cast iron ones
                  91 Dodge caravan 7/8 aluminum/plastic reservoir.
                  My car has the large GM calipers all the way around. A 1" mc with the brake pushrod moved up on the pedal. With the small metric calipers you may want to go with a 7/8 or 15/16. Too large of a MC will make it harder to push the pedal. Too small will take more pedal travel to apply.
                  Front or rear port. If both pistons are the same size then they both put out the same pressure. Dont let any one tell you other wise. The only difference on the cast style is one port has a large res and the other has a small one.
                  Nick
                  • brummi5050
                    • Nov 2010
                    • 14
                    #39
                    Nick
                    Now were talking. Thank you this really helps. I read the brakeman article and missed the part On most American cars and trucks up to the mid 1960's had valves in the MC. My stocker is either 7/8 or 15/16" piston which should be fine for my application once I get rid of the combo valve. Thanks again! Mark
                    • dirty white boy
                      • 1238
                      #40
                      Nick
                      great post!
                      white trash motorsports
                      • Egoracing
                        • 4852
                        #41
                        Nick
                        Wilwood has a 7/8 Caravan master that they took the plastic piston and made an aluminum one for it and that was the only thing they did. We busted one in a wreck and got a standard opne out of the Junk Yard and used the aluminum piston in it and kept using it.
