Widening Metric front end
  • nova21j
    • 32
    Are there any other lower a arms that will fit a g-body metric car to widen the front end other than the early novas. I have a ton of 5 1/2 front spring and dont really want to buy all new 5". Thanks
  • fast_crew
    • 844
    There is a Ford crown vic that fits not sure years. Maybe lengthen the metric lowers?
    Josh K.
    • 1bbmft
      • 1388
      Camaro
      70-81 Camaro lowers will bolt right on.
      • stock car driver
        • 3233
        both of these last two guys are posting wrong info.
        the ford go on the camaro clip or full size
        metric uses the early nova stuff its not a bolt on job tons to change
        • racin6mod
          • 2172
          the ford crown vic lower can be made to work but you have to cut off the lower rear frame mount and move it about 3/4 of an inch.the same for the camaro lower's it take work but it can be done. the nova lowers also lengthen the wheel base because you have the put them on backwards to make them work.
          • fast_crew
            • 844
            Impala spindles arn't a bolt on either...I wouldn't do it to much work.
            Josh K.
            • gun91
              • 288
              I have been thinking about building a new metric car, but taking the bare frame and cutting it down the middle and widening the crossmembers and centerlink has anyone ever done that?
              • dirty white boy
                • 1238
                why dont ya just run a shallow'er wheel off set,...going from a 4'' to a 2'' youll be 4 inches wider....spacers can work too....
                white trash motorsports
                • gun91
                  • 288
                  My reasoning for widening the frame is to put the springs farther apart. I think it would make the car more stable and predictable.
                  • beer30
                    • Apr 2008
                    • 55
                    1982 and newer camaro will bolt right up . i think they are longer than the g body metric.
                    • dirty white boy
                      • 1238
                      82 an up are strut cars,...will that work with coil springs???
                      if you want wider springs why not go with a chevelle or camaro clip???
                      • gun91
                        • 288
                        Yea but the way I am thinking about doing it, I can go ahead and make it a little wider that the older frame.
                        • wildchild111
                          • 268
                          that is cheating and shouldnt be done !!!!!!!!!!!!!!
                          http://www.impeachobamacampaign.com/
                          • gun91
                            • 288
                            My tracks rules say NOTHING about widening the frame and all my suspension mounts would still be in the same place. What about people moving the top a-frame mounts? That is done ALL over the country!! You will be hard pressed to find a front running car that hasn't had the top a frame mounts moved or the a frames themselves lenthened or shortened!
                            • RCJ
                              • Nov 2007
                              • 509
                              I had a metric modified that I cut the a arm at the bushing then took a second a arm and cut about an inch or 2 from the bushing and welded that piece on the first a arm.Welded my wieght jack where it fit the spring.You want the tallest lower balljiont in it, moog 727 If I remember right
