offset spring perches
  • superstock_53
    • Oct 2009
    • 54
    has anyone tryed messing with offseting the spring perches on a metric car with stock spring pockets and stock shock location... was thinking about trying it just want to see if anyone else has and did it work
  • dirt daddy
    • Oct 2011
    • 34
    I move my left side close 2 the tire & as far forward as i can
    Demon Chassis
    • superstock_53
      • Oct 2009
      • 54
      so if i put a clamp on spring perch that hangs off the back of the axle tube on the left and straight up on right it aint going to do nothing for me
      • dirt daddy
        • Oct 2011
        • 34
        Its all bout how it feels 2 u what some like others may not puttin the spring on the front side of the rearend gave me a lil more bit on throttle would say it was alot but evey lil bit is helpful i thank dont b affraid 2 try new stuff u might find something that most people say is crazy & wont work but it might 4 u
        Demon Chassis
        • hoosierdaddy48
          • 150
          my dad runs a 74 chevelle. in the 2010 season he ran the springs in stock location and was pretty fast but i could usually hang right with him in my camaro. 2011 season all he did was move to a 16" spring 3" infront of housing and he has been unstopable. i ran second to him once this season while he was trying to lap me. hes even won a few open comp type shows against 3 links. i honestly have no idea how or if it works, maybe it just suits his driving style.
          • Greg Peck
            • 11
            Offset Springs
            If you move the LR spring ahead of the axle like was stated you are creating a TON of drive. IMCA only allows you to move the spring forward of the center line of the axle equal with the back of the spring. With the spring 3" ahead of the axle all the rotation of the rear end is compressing that spring, creating drive for the LR. Many Modifieds are setup this way when they don't mount the spring on the bird cage.
            • 4bangerhotrod
              • 374
              if the axle is rotating its going to act just like a 4bar late model, as the rear end wraps up it is compressing the spring adding more force to the LR tire than if the spring was mounted in the center of housing. the more force you have on that tire the more forward you will get. going 3in ahead of axle is really compressing the spring quiet abit.
              • 4bangerhotrod
                • 374
                i dont know, i dont run these cars but im sure if your changing pinion angle the housing is rotating. if people are gaining 8-12 deg of pinion angle its rotating somehow
                • dirt daddy
                  • Oct 2011
                  • 34
                  Dont u jig ur rearend 2 reduce "ROTATION"
                  Demon Chassis
                  • dirt daddy
                    • Oct 2011
                    • 34
                    Dont have a site or anythang like that & im not sayin ur doin anythang wrong theres a hundred ways 2 do 1 thang u kno that
                    Demon Chassis
                    • a1driver
                      • 227
                      how do you know you are only gaining 2 degrees of pinion angle? i find this very unlikely, unless you haveno forward bite.
                      • dirt daddy
                        • Oct 2011
                        • 34
                        No got a few on facebook book
                        Demon Chassis
                        • stock car driver
                          • 3233
                          share here or post a link?
                          • a1driver
                            • 227
                            i would hope your rearend doesnt rotate with the car setting on jackstands,lol. what happens when you apply the rotational forces of the tires reacting on the rearend through the control arms?
                            • 4bangerhotrod
                              • 374
                              if your upper and lower control arms are at different angles your rearend has to rotate some through the suspension travel. not counting the give in your bushings unless your running metal or mono ball bushings plus im sure theres flex in some parts somewhere.
