Trans housing breaking
  • superstock_53
    • Oct 2009
    • 54
    so this is the second time that the housing had broke on me... i have solid motor mounts up font and i have a urethane trans mount... its a metric chassis full cage from front to back and the frame is boxed in.. running the stock trans cross member... any help any one know what the solution is
  • turner
    • Apr 2008
    • 193
    Make sure your driveshaft isnt bottoming out. I had this happen at the end of last year. Yoke was to long and kept breaking trannys.We lost driveshaft and everything though, so not sure if it would just break case and not throw a driveshaft.
    • Driver88
      • Sep 2011
      • 104
      Is it breaking tail shaft or ears off? I have always been told if ya run solid motor mounts run solid trans mounts and thats what I do.
      • SRT17
        • 172
        I use solid mounts front and rear of the motor, and let the trans hang on the back.... with a stock bell housing... Never had a problem...
        • superstock_53
          • Oct 2009
          • 54
          here is a link to my facebook and the pic of the trans https://www.facebook.com/photo.php?f...type=3&theater
          the drive shaft is not bottoming out.. do you think if i just run the trans mount and not bolt it to the cross member help any
          • speedbuggy
            • 259
            I used to break trans just like that. Started just putting a stud up through the crossmember and only running the nut up far enough to stay on the end of the stud (basically what you are talking about doing only using a stud and nut to keep the trans from wallering all around on the crossmember). Never had a problem since.
            Also, could be driveshaft out of balance.
            • Driver88
              • Sep 2011
              • 104
              This is what I currently do as well but before this. I had the top part of a mount bolted to trans and a spacer welded to it with a bolt thought crossmember.
              • Dirt Knife
                • Jun 2012
                • 147
                chassis flex
                Run urethane motor mounts and trans mount.
                You have chassis flex. Unless you run mid plate??
                I Never broke one except for the u joint failure on the front yoke.
                Just my opinion
                • dirty white boy
                  • 1238
                  bust off rest of bell an you can buy a SFI bell housing that bolts up where pump cover dose an save the transmission
                  white trash motorsports
                  • 26-62 racing
                    • Dec 2009
                    • 147
                    Do what ever you can to make sure your drive line is in proper alignment and not binding any where. For either manual or automatic, check to make sure that the bell housing is centered to the center line of the crankshaft by using a dial indicator and offset dowel pins. We use front mounts. mid mounts and transmission mounts. The motor mounts are steel with the transmission mount factory rubber mount. We use the rubber mount mainly to just support the weight of the transmission. When tightening down the mounts if their is any gap between the mounts, install shims between the mounts to fill the void so not to put anything in a bind which will lead to breakage. Try for as close alignment as possible between the center line of the front of the crank, output of the tail shaft and the center of the pinion. The other post are correct on the drive shaft. Make sure the yoke is not bottoming out to the tail shaft, and the drive shaft is in proper balance. Talked to Bushore transmissions and he said that over 75% of the broken cases for automatics were from drive shaft being out of balance. Even some of the drive shaft companies were sending new factory made drive shaft out of balance.
                    Hope this helps. Just check everything, I have races the same power glide for years with no broken case, even after pounding the wall.
                    Mike Bulpitt
                    26B 62B
                    owner driver builder
                    • superstock_53
                      • Oct 2009
                      • 54
                      well i broke another housing this time its on a powerglide cracked right buy the reverse band... with the rear end jacked up with out springs in i still have about 2ins of space between the driveshaft and housing.. i had soild motor mounts with a stock rubber mount for the trans... im going to have the driveshaft balance this week. and weld a x brace...
                      • dirty white boy
                        • 1238
                        drop rear end an see how much clearance you have on yoke then...if your still good on clearance then might wanta try some rear moter mounts or mid plate...
                        • speedbuggy
                          • 259
                          One thing I saw on here a LONG time ago was that a guy had a bent pinion gear in the rear end causing this. Might as well check that while you're at it.
                          • 26-62 racing
                            • Dec 2009
                            • 147
                            How in the world would you bend a pinion gear?
                            Mike
                            • Hurst390
                              • Mar 2010
                              • 188
                              I built these struts out of chromoly...very light and I hope to be effective..
                              BIG Headers
                              Barry Allen Racing Engines
                              Bret Kepner Photo's
                              http://i23.photobucket.com/albums/b3...psc5b73510.jpg
                              http://www.youtube.com/watch?v=8CQprfva4Tg
                              https://www.facebook.com/pages/Landi...10973822308754
