i have been having the same problem - after breaking the 5th one i heard about a part (someone else mentioned it as well) it is an aluminum cast bell housing - the part is made by jw performance - not sure what tranny you are running but they make it for a turbo 350 and 400 or the powerglide which is what i run - you have to cut the bell housing off and the part is a stronger bell housing that then bolts to the pump (you have to get the bolt kit too) - so far i have run one race with no problems and running again this weekend - its supposed to be 600 times stronger than the standard case - both summit and jegs sell the part - for the powerglide the part number is 92450 and will run you about $285 with the bolt kit
Trans housing breaking
sure is better!! the drag strip boys turning big power been useing them for years!! its sfi rated too!!Originally posted by motorsports12 View Posti have been having the same problem - after breaking the 5th one i heard about a part (someone else mentioned it as well) it is an aluminum cast bell housing - the part is made by jw performance - not sure what tranny you are running but they make it for a turbo 350 and 400 or the powerglide which is what i run - you have to cut the bell housing off and the part is a stronger bell housing that then bolts to the pump (you have to get the bolt kit too) - so far i have run one race with no problems and running again this weekend - its supposed to be 600 times stronger than the standard case - both summit and jegs sell the part - for the powerglide the part number is 92450 and will run you about $285 with the bolt kitwhite trash motorsports
broke another one.. i x'ed the frame. put in rear motor mounts and built one of them trans struts and still cracked the bellhousing.. so now what...
You are very frustrated, i would be also, you could be missing something that you just don't know of. We all have to learn , sometimes the hard way, just like this problem. How about asking another good running local racer, who runs a power glide, to stop by and check out your car looking for something you have missed, or just don't know, yet. Buy him dinner and a beer. If you were closer I would stop by, just to try and figure it out, and help. Another thought send me a pm I would talk to you on the cell if you want to. Might be able to help in some way.
Mike
I have solid motor mounts and no trans mounts. Seen too many problems with trans mounts.Web: http://www.t17.co
I saw this happen to a guy at my track. His problem was the driveshaft was too short. During the normal suspension travel it would pull out too far and get into a bind that didn't allow it to go back in.
Put it up on jackstands and see how much it pulls out.
found out the problem... the drive shaft was bottoming out at one point the u-joints flattened and put he shaft in a bind ... problem solved.. thanks everyone for there opinion it was a real mind twister
i was afraid you were checking this wrong when you posted this...glade you finally got it sorted out!!Originally posted by superstock_53 View Postwell i broke another housing this time its on a powerglide cracked right buy the reverse band... with the rear end jacked up with out springs in i still have about 2ins of space between the driveshaft and housing.. i had soild motor mounts with a stock rubber mount for the trans... im going to have the driveshaft balance this week. and weld a x brace...white trash motorsports
