Left Rear Spring Falling Out
  • stock car driver
    • 3233
    #46
    Originally posted by hot_rod View Post
    Well that was the theory behind why I put it in. I don't think that there is a lot of pressure being applied to the LR, but it has more than before. I can't say what exactly was the overall contributing factor to the car running as good as it did,but the only thing that changed was the spring. With the new setup, I might not be able to run high on the track anymore. Our track is so rough that high is generally the better line if you miss the giant holes and ruts. Since a lot of people don't run down low it seems to hold together better. I am extremely happy with the setup, the only thing that I regret is waiting until there was only 3 races left in the season when I put it in.
    This is pretty close as to what I actually have:
    Old: 13" 250 compressed to 9.5" = 875lbs
    13" 250 no compression = 0lbs
    New: 16" 100 compressed to 7.5" = 850lbs
    16" 100 compressed to 3" = 300lbs.
    To me the 300lbs in the LR is better than the 0lbs. I'm approximating the compression for the 16" in the corners but that is close to what the car is rolling over. So there is my logic and thought process. It might be completely wrong but it worked out for me.
    a 16 250 would have been better
    But like I said if it worked then something else is working for you not the spring, lol..
    • hot_rod
      • Jun 2010
      • 99
      #47
      I can't say that the spring was the fix all either, but I'm pretty happy with it.
      • stock car driver
        • 3233
        #48
        Were you able to get back to the same amount of bite and wheel weights with the soft spring?
        • stock car driver
          • 3233
          #49
          And yes I would be happy too if it works..
          Im hoping that my rf frame being bent up a inch and a half will make the car faster, lol..
          I fixed the left sunday am and bent the right sunday pm. two weeks ago. Its been a rough two weekends at special events. Was towed off on 2 trucks last friday, replaced everything for saturday, won the b and bent some stuff in it on a tractor tire.
          ran the a and car was a handfull finished 11th and found steering box sloppy and idler with half inch of play.
          • hot_rod
            • Jun 2010
            • 99
            #50
            We never wrote down what the setup was before the spring. We scaled it in the middle of season. I remembered what the cross percentage was and we got it back to where it was before. The wheel weights was something that we should have written down, but I got all of the percentages to what we thought they were before and I know that we put the cross back.
            Well Jeff hopefully your luck will turn back around. After I t-boned the wall in June we had to have my right front pulled. My car now is the best that I have ever had.
            • tpl12blk
              • Oct 2011
              • 2
              #51
              Thanks so much for this! This is exactly what I was looking for
              Toplantı Bloknotu
              • stock car driver
                • 3233
                #52
                Well Jeff hopefully your luck will turn back around. .
                survived night one
                4th in passing points out of 44 cars
                4th in the 15 car pole dash which the top 6 got locked in
                got to 2nd easy behind a good friend so was taking it easy and happy with being locked in and two guys decided they really wanted to mix it up banging on me and each other so i ended up 4th, no flats etc, lol..
                • Driver88
                  • Sep 2011
                  • 104
                  #53
                  I still don't understand how you completely unloading the LR. Unless something else is wrong.
                  Have ya got the back of the car way up in the air? Is the RF really soft?
                  I'm just don't understand how ya completely unloading a 13 spring with a weight jack.
                  • Dirtrunner35
                    • May 2010
                    • 632
                    #54
                    A 100lb spring with 300lb on it will compress 3 inches
                    A 250 lb spring with 300 lb on it will compress 1.2 inches
                    So if your 250lb spring compresses 3 inches it has 750 lb on it.
                    A 100 lb spring with 750 lb on it will compress 7.5 inches.
                    • wrengoodman114
                      • Jul 2009
                      • 559
                      #55
                      Your welcome hot rod still doing good with soft spring?
                      Wren Goodman
