First time building a mustang dirt track car
  • Mudstang22
    • 6
    Hey guys, I'm jumping into the dirt track world and have a fox body mustang 2.3l. at this point I am looking for advice on where to begin with the suspension setup for a 1/3 mile track. Anyone have any suggestions? Thanks!
  • Mudstang22
    • 6
    Ok so I haven't had any replies yet to this post, but it's ok. Basically what I have is a factory fox body mustang. I believe it's factory suspension all the way around. Would it be best if I just run what is on there and see how she handles, then tune accordingly from there? Any information would help at this point. I see on some other posts that the right front should be stiffer than the left and the left rear needs to be soft for going though corners. I just don't the know the specifics. Thanks!
    • FATMAN
      • May 2008
      • 51
      hey been years since I drove but here is a link to a good start.
      http://www.4m.net/archive/index.php/t-197190.html
      Daniel #27 mini stock
      • Mudstang22
        • 6
        Hey thanks! I really appreciate it!
        • fastford
          • 4059
          one thing i remember from back when they ran them here , the cars running up front took the left upper control arm off the rear end to keep the rear from binding up , kind of like a 3 link.......
          • Mudstang22
            • 6
            Ok, I'm not sure I understand what you mean. It's a solid axle on the rear end so there is no control arms. My mustang is an 89. Can you explain a little more? Thanks!!
            • fastford
              • 4059
              the fox rear is a 4 link with out a panhard bar , it uses the upper control arms to locate the rear side to side like a metric gm chassis , the only difference is the rear springs are located on the lower control arms , which is called a swing arm in late model terms , unlike the metric , that has the springs on top of rear , you can remove the left upper control arm and leave the right upper on to control side to side , the advantage to this is the rear will not bind up under body roll , like a metric , keeping the left rear tire on the ground . you can understand this better if you jack left rear up with left upper bar on and see how far tire drops , then take it off and jack up , you will be surprised ...
              • Mudstang22
                • 6
                Oh! Awesome thanks!
                • fastford
                  • 4059
                  all so , because a strut front end will not gain camber like a suspension with a upper A-arm will , you have to start with a lot of static camber in the right front , best i can remember , we ran some where around 6 to 8 degrees , i would start there and check my tire temp across the tire to fine tune , hope this helps you , good luck , one more thing , a 2 to 1 quickner works out pretty good with a stock rack...........
                  • Mudstang22
                    • 6
                    This is great info, and I truly appreciate it. I do have a quickener on the steering so i think I'm headed in the right direction. I'll keep you posted on the progress and once again thanks!
