neon set up help?
  • badmojoracing
    • Jul 2011
    • 15
    neon set up help?
    IMCA rules apply...
    Looking for a good starting point for suspension setup. I am brand new at dirt circle track and would like to start right.
    Gen 1 Dodge Neon - SOHC 5 spd
    the course is 1/2 mile medium bank dirt / clay oval.
    With some luck I will make my debut yet this season but have to finish the car set up 1st.
    Mike
  • boportt
    • Aug 2007
    • 190
    get a trany frm a srt4 its gotta pozi and beter rato
    • badmojoracing
      • Jul 2011
      • 15
      SRT tranny
      Good thought... All the SRT trannys I have seen price out about $1500 bucks which is exactly the claim for sport compacts in IMCA.
      How about a PT cruiser? or are those the same 5spd as the basic 1st gen neon?
      • boportt
        • Aug 2007
        • 190
        only the srt4 gots teh pozi. duel cam neons got the same rato but aint posi. if u look around u can find them pozi trans for lots less than $1500. try neons.org for some good tech info. http://www.neons.org/forumdodge/trans.htm
        • badmojoracing
          • Jul 2011
          • 15
          Will keep looking...
          THx..
          • 472 DAD
            • Jun 2008
            • 69
            There is a lot more involved than just swapping the trans. The T-850 trans (SRT) has a hydraulic clutch assembly. So when buying the trans you will need the peddle assembly also. Don't forget the brakes are also on this assembly and I believe it is different from the 1st gen also as far as the length and throw. Seems like a lot of work for a heavier trans with posi.
            • boportt
              • Aug 2007
              • 190
              it aint no biggy to just swap out front 1/2 of trans thats wat everyone does here
              • dirtcarracer
                • Aug 2010
                • 122
                if i was him i wouldnt even do anything about the tranny, i would change the tire size which in turn changes the ratio of the gear, and you really only have to use 1st and 2nd
                so it would be just a waste of time and money to change tranny. jmo
                • boportt
                  • Aug 2007
                  • 190
                  thats some redneck bull$hit cuz thers allot of neon gear ratios and ud never use 2nd gear ona 1/2 mile or ud need 235.85.16 truck tirs cuz in 2nd hed be cranking 10k with even 14's yall need dohc trans 3,94 diff and 13" tirs and she ll be perfect r's and and thats' what the srt4 ratio is and then yall got posi too so u can sit on the porch or run w the big dogs.
                  • badmojoracing
                    • Jul 2011
                    • 15
                    sooo....
                    It would appear you can run a dohc tranny get the same gears as a t850 but without the posi. Of course they make a posi unit for the t350 which then would essentially be the same thing as a t850 only without the clutch swap hassles ; right?
                    it is a 1/2 mile and honestly i would think you'd spend the entire time in 3rd gear but not having run the car yet i cannot confirm that.
                    this is a fast track...
                    for the extra cash does posi really help that much. I honestly think it would be illegal as besides the SRY none came with posi and this is not an srt - might be a little obvious. Our tech guys are sharp and neons are common enough im sure they've seen most everything tried - lol...
                    M.
                    • boportt
                      • Aug 2007
                      • 190
                      the nisan spec v comes with posi and soe does some acuras the guys w/o pozi don't keep up with guys that do. but i can tell u that u aint gonna run 2nd on a 1/2 mile track unles u r running 16" truck tires. we run t850 1/2mi hard clay turn 7800 w/. 72" rollout
                      • badmojoracing
                        • Jul 2011
                        • 15
                        So are you running in 2nd or 3rd? I may not be reading your post right?
                        • boportt
                          • Aug 2007
                          • 190
                          on a 1/2 mile u gotta run 3rd 136 is the gear 394 diff = 535 wich is perfect for 1/2 mile w/13" liek 205/.60 13 tire u shuld be turning 7300 or so
                          • Irace93
                            • Feb 2010
                            • 54
                            You Picked the Tranny perfect but For tires you guys on here need to learn to Measure the tires around then theres NO CONFUSION! if its a 205/50/14 or a 195/65/15 IT DONT MATTER!
                            You wanna start with a tire that measures 72" around and Adjust accordingly it depends on the track grip, where your running in the corners, slick,tackey, Whatever!
                            tall 13" medium 14" or a Wider 15"
                            • boportt
                              • Aug 2007
                              • 190
                              ur a fu ckin retard. 205/60/13 is 70" around and also liter than 14 and 15" wheels/tiers
                              it dont mater if u got 13, 14 or 15" a 205 tier is the same and 60 is % of 205 so a 205.60.13 has the same hite from the rim to the thread and if you mesure around the tier a 13" 205/60 will be like 70" a 205/60/14 will be like 73" around and a 205.60.15 will be like 76" aroud
