2.3L crane cam ID, need help...
  • Dirtman29
    • 1690
    I bought a complete 2.3L ford head, has a crane hyd. cam in it, cannot find any info on the cam anywhere. I was told by seller its .440 lift.
    19-38-01, H2902 are stamped on the back of cam. Any help greatly appreciated.
  • Milford Motorsports
    • Jun 2008
    • 285
    H2902 is not a Crane #. Found a Lunati #32902 hyd. 508 lift 310 dur.
    • Dirtman29
      • 1690
      It has "CRANE CAMS" stamped on the back also. No idea how old it is, maybe a discontinued part?
        • Jun 2008
        • 285
        There is a Crane cam listed on Ebay,on the cam card it lists a Crane Grind #.Very similar to your's.Most likely what is stamped on your cam.There should be someone out there that can cross reference the grind # to actual spec numbers.
          • Jun 2008
          • 285
          http://www.ebay.com/itm/250965040578...84.m1438.l2649
          • Dirtman29
            • 1690
            Thanks for the info. I may call Crane directly & see what they know about it.
