Abs
  • DJR22
    • 48
    Abs
    As far as stock compact type classes go...how do anti-lock brake equiped cars behave on the ovals? Is the ABS helpful or hurtful? Run it as is? Eliminate it? Any tricks?
  • return to dirt
    • 1008
    i would disable it. it would be too erratic on a dirt track. not sure about a paved track. should be able to pull a fuse or relay to disable it and the brakes then should act as normal brakes.
    olin
    • Jk21
      • Jan 2012
      • 5
      Abs
      I know a guy who runs traction control on dirt rear wheel drive mustang and it works good and even easier to hide.. Helps you not to spin as much
