As far as stock compact type classes go...how do anti-lock brake equiped cars behave on the ovals? Is the ABS helpful or hurtful? Run it as is? Eliminate it? Any tricks?
i would disable it. it would be too erratic on a dirt track. not sure about a paved track. should be able to pull a fuse or relay to disable it and the brakes then should act as normal brakes.
