belt numbers
  • dannyracer6
    • 1063
    belt numbers
    In the past I have run the esslinger power pulley and a stock type waterpump, steel, pulley. I have gotten an alum esslilnger 7" and I am not sure of the belt size to use with this setup.Since the stock pulley is on the shy side of 6" I would think the numb er I used with it would be wrong for the Power pulley and the E 7" aluminum. Thanks.
    dr6 motorsports
  • crcltrakr
    • 293
    Belt
    Dan:
    Get a belt that has the right cross section & is too long, cut it and wrap the pulleys then trim at the over lap. Take it to a "real "parts store, the belts are marked with a number that relates to section and length. They should be able to get you real close. Or you could wuss out and add a power steering pump or an alternator to use as an adjuster.
    Hope this helps!
    JerryM
    • dannyracer6
      • 1063
      Thanks, Jerry.
      We have an alternator so we can just run one belt.
      dr6 motorsports
      • Old Rob
        • 1027
        The 7" WP pulley and 4" power pulley use a 15301 belt between them. If you're also driving an alternator the as stated you just need to measure it with a junk belt cut to lentgh, just slightly shorter than where you want to run the alternator adjustment.
