I have a friend that has been having Hyd. lifter problems. Breaking them to be exact. He has been using stock replacements from the auto parts. The cam is supposed to be 530 lift Hyd. cam. I have never heard of one that big but if it is, could he be coil binding the spring causing the lifter probs? Or is it just cheap lifters and he needs to go with better lifters. Something like what esslinger offers or is there something better?
Lifter problems.
Stock lifters should not break,something is not right.Coil bind,retainer hitting valve guide boss,bad guides,valves hitting pistons,too much spring pressure,cam timing not correct,lash not set properly.Pull the valve cover,turn the engine over with a wrench.Closely watch what is happening with the cam and valves,the problem should be easy to see.
The engine builder he uses doesn't do much 4 cylinder stuff so I am not sure he know what to look out for as far as our cams go. I think he may be to high on spring pressure. I will get the cover off tonight and see what I can find.
I have seen a lot of heads lately with way too much spring.Some of the big name mail order companys seem to be pushing springs with too large of dia. wire,especially in the roller heads.Probably cheaper to stock one size spring and sell it for all apps.110 - 115 lbs. closed pressure is the common average.
I talked to the guy this morning, he replaced 4 damaged lifters and he said the rockers and cam are wore. The head is going to another engine builder Monday. I'll let him in on the 110-115 spring pressure info. Thanks for the help.
we run 120 but thats close ! this guy has lots of problems if cam and followers are worn!! geometry is not right on cam!Originally posted by Milford Motorsports View PostI have seen a lot of heads lately with way too much spring.Some of the big name mail order companys seem to be pushing springs with too large of dia. wire,especially in the roller heads.Probably cheaper to stock one size spring and sell it for all apps.110 - 115 lbs. closed pressure is the common average.
i run .040 on all of our hydraulic cams...havent lost a follower yet and it has been over 10 years.Originally posted by Dan32 View Postbetter close it up tigher than that or you will through rocker off!!No matter how hard you try...you cant fix stupid!!!
www.raceidaho.com
We've been having the same problem lately. We had 6 bad lifters last week while having a fuel pump issues which cut the rpms down to 7500 from the normal 8000. The engine builder is gonna stop by and look the head over were suspecting it's the lash is improperly set. Hopefully we can get this worked out soon.
