Rotors
  • hector
    • 66
    Rotors
    Looking for a brake rotor to fit a 9 inch ford with 4 on 4 1/4 bolt circle any one have a idea i got 1 need another and also if some one has done this what calipers could u use have limited space running a 13'' wheel.....
  • Headhunter
    • 1338
    Flyin Bryan make a bracket for the escort front brake calipers that uses the escort rotors.
    • steveshawjr
      • Jan 2008
      • 430
      we use the turbo coupe rotors on the 7.5" rearend with a gm metric caliper and modifed the bracket you can buy to weld on a 9" to shorten it up to fit the 13" wheels
      now my question to you is where did you get 4x4.5 axels for the 9" i cant seem to find them
      62 mini mod
      • car62
        • 1579
        Moser makes a 4 on 4.25" 4 lug axle for the 9"
        www.raceidaho.com
        • Foghorn
          • 293
          A poor mans way to do it is take the axles you have and knock out the studs. Weld up the holes. Put the axle in a lathe and true it up because the flange will distort abit from the welding. While it is in the lathe, index the flange for whatever bolt pattern you like. Drill holes. Install some good quality studs and that's it. It is easy to do and cheap. Plenty good for a ministock. I have done it lots for people over the years with no problems. No need for aftermarket axles.
          • Wrencherer
            • Aug 2009
            • 108
            The Ford 8" axles will work in a Ford 9"
            • pilotracer
              • 160
              read
              anyone got the hot ticket for slotted rotors for a mustang
              • Foghorn
                • 293
                Wrencherer. The 8" axles only fit the 9" diffs with 28 splines. Most 9" diffs are 32 spline. PilotRacer. Why do you need slotted rotors on a Mustang ministock? If you need big brakes on a ministock then you aint driving properly. Use momentum and you don't need a bunch of brakes.
                • Wrencherer
                  • Aug 2009
                  • 108
                  Foghorn
                  You are correct, but all you have to do is change the spool to get what axle spline you need wheather it be a full spool or a mini-spool.
                  • pilotracer
                    • 160
                    read
                    whats the deal on here you ask a question or where to get something or if anyone knows where to get it and its your not doing something wrong you dont need them your dumb dont ask stupid question if you got to have that you set ups not right why cant want something (not a nice word)(not a nice word)(not a nice word)(not a nice word) never seen so many negative people
                    • Foghorn
                      • 293
                      People are trying to help you. Can't you figure that out? You don't need big brakes or drilled, slotted rotors on a ministock. You use momentum on low powered cars like ministocks. If you need a bunch of brakes you are doing something wrong. If that hurts your feelings then you are in the wrong sport. Get over it.
                      • car62
                        • 1579
                        or maybe Faghorns car is so slow he never needs to use the brakes.
                        im one of the fastest cars in my division and i use a ton of brakes.
                        www.raceidaho.com
                        • Foghorn
                          • 293
                          I have raced alot of different vehicles in my lifetime and won many races. I haven't raced a ministock in quite some time but they haven't changed much in 25+ years. I was never hard on brakes. Some guys are. Ministocks have no power so if you use momentum you don't use your brakes nearly as much. The fact that Car62 uses a ton of brakes tells me if he changed his driving style he could go faster and save money. I have coached alot of kids starting out in ministocks and the ones that drove go-karts understood the momentum idea and were better on equipment and went faster. Just because Car62 is hard on brakes doesn't mean he knows how to drive.
                          • pilotracer
                            • 160
                            read
                            OMG there just rotors everyone has stuff they dont need gessh and for your info i run three tracks a week over 20 fast times over 40 wins and 60 plus top threes i can get it done i didnt ask if they will help me if i needed that info i would of just tried it a friend has some and says there nice and i liked them and wanted them too everyone has wants for no reason !!!!!and i did start out in karts to
                            • Foghorn
                              • 293
                              Why the hell don't you just ask your friend where he bought them then? Plus I was talking to Car62 not you.
