Ok ive heard from a few guys this year that you can run a hydraulic cam in a solid lift head. Any truth to this. I got a solid head with a 510 cam thats to big for our rules. And another head that is cracked. Could I take the followers and cam and throw in the solid?
2300 hyd cam in solid head?
hyd. to solid no ! solid to hyd. yes!! ram speeds are different ! if it works cam want last long hyd. is to soft of metal!Originally posted by Ministock25 View PostOk ive heard from a few guys this year that you can run a hydraulic cam in a solid lift head. Any truth to this. I got a solid head with a 510 cam thats to big for our rules. And another head that is cracked. Could I take the followers and cam and throw in the solid?
hyd. cams have diffrent ram speeds than solids the grinds are different!Originally posted by mus06 View Postwhat does it gain over just run a hyd cam say i am running a 480 hyd head shaved to the may stock valves no port and polish now i put a 480 soild cam in the same head what would make it better then before
