alky on a 2300 ford
  • grydergeyer26
    • Oct 2008
    • 168
    alky on a 2300 ford
    i got a alky carb for my mini stock and was wondering were i should start jet wise i ran 76 jets n my gas carb somebody said double it is that right it came with 162 and 164 jets
  • Robertms
    • 113
    Alky carb
    I assume this is a 500 cfm carb and if it is we run 136-138 jets for a 2348 CC engine. It was a rocket off the corner. Robert
    • grydergeyer26
      • Oct 2008
      • 168
      yes a 4412
      • grydergeyer26
        • Oct 2008
        • 168
        wjat intake would u run esslinger or efi
        • let-r-eat
          • 2319
          Depends on what metering block you have. Does the metering block accept the large Alky jets? If so, 140's is in the ballpark.If it has the hole above the jets *which I don't like* then depending on the hole size probably 84's or so.
          BUCKLE UP NOW, YA HEAR?
          • huntingeddie03
            • Aug 2008
            • 15
            Ford 2300 on alky
            Is there any thing more you got to do to the motor to run alky? And do you notice a performace dif?
            • let-r-eat
              • 2319
              No. Run it and you won't want to go back to gas. Substantial difference.
              • blue
                • 16
                I assume when you say alcohol, you mean methanol, not ethanol, which is available in E85 pump gas, correct?
                • grydergeyer26
                  • Oct 2008
                  • 168
                  what squirter did u run and accel pump on your methanal carb
                  • grydergeyer26
                    • Oct 2008
                    • 168
                    need help what fuel pressure regulater do u run i am running no return line
                    • grydergeyer26
                      • Oct 2008
                      • 168
                      help anyone or does anyone know were i can get it
                      • let-r-eat
                        • 2319
                        Regular ole holley regulator will work. Use the holley needle and seat brand only and around 6.5 on the fuel pressure. The holley brand needle and seat will hold more pressure before over running the float. Get everything warm and set the idle. The idle will tend to rise after a heat race because heat makes the engine more efficient with alky making it have a leaner idle when warm and idling up.
                        • grydergeyer26
                          • Oct 2008
                          • 168
                          so i dont have to run a return
                          • purestock45
                            • Mar 2010
                            • 130
                            no return needed as long as your not over 8 psi...alk. motors tend to like more timing also..
                            • grydergeyer26
                              • Oct 2008
                              • 168
                              I am running at 8psi
                              I wondering if I am throwing to much fuel at it and the boosters r filling up cause it has a hick up in the corner been fighting it all year and still am
                              it has .130 needle and seat and the float level is in consistant
