Tight Mustang
  • threed247
    • Oct 2012
    • 8
    Tight Mustang
    3/8 dirt mild banking will not turn on entry driving in smooth on throttle. i have not been on scales yet. springs are RF650 LF600 RR175 LR150 1 1/2" stagger. LR spring cup about an 1" more compression than RR cup just set ride height. This looks like too much cross. Have seen set ups with heavier spring on LR What is the difference in handling with higher spring rate on left and setting equal cross weights. I want to drive like I drove carts. Thanks Guys
  • Dirtman29
    • 1690
    More info needed...
    Stagger in front or rear?
    Air pressures?
    Wheel offsets?
    Weight(lead) in car?
    3 or 4 wheel brakes?
    • threed247
      • Oct 2012
      • 8
      Front even ,rear has 1 1/2 stagger ,all wheels 7"wide 3" offset, air 12 lbs left side 15 lbs right side , no extra weight in car battery behind seat I'm 195lbs fuel cell in trunk against left rail, 4 wheel brakes but don't want to use them. rear locked.
      • 84Dave
        • 915
        Set the cross no more than 2% above rear %. Try 2" of stagger up front & 2.5"-3" rear. -Dave-
