2.3 Ford lifter issues
  • CnDRacing
    • 118
    Has anyone else had problems with 2.3 Ford hyd lifters "mushrooming" the crimped on tops? Once this happens the engine either misses and/or runs "flat" at the upper rpm range. I've been having this issue for the last few weeks. Engine guy says springs are set correct. RPM has been between 7500 & 7800. Using std oil pump and 20w-50 oil.
    Any help into what is causing this or how I can fix the problem?
    Thanks
  • drtlvr
    • Feb 2010
    • 233
    110-125 seat 250-275 open spring pressure. .040-.050 lash with lifter collapsed.
    • Big E tech
      • 104
      Dirt lover is correct! Sounds like you have exceeded the rpm that you have springs to control!
      • CnDRacing
        • 118
        Thanks for the information guys.
        Big E, do you stock springs that would fit my application and if so, what is the part number?
        • drtlvr
          • Feb 2010
          • 233
          They also have printable instructions on their site on setting up hydraulic heads.
          • Big E tech
            • 104
            Use our pn#E3207 for valvesprings on the hydraulic heads
            • CnDRacing
              • 118
              Thanks Big E
              I ordered those and the matching retainers last week.
