Has anyone else had problems with 2.3 Ford hyd lifters "mushrooming" the crimped on tops? Once this happens the engine either misses and/or runs "flat" at the upper rpm range. I've been having this issue for the last few weeks. Engine guy says springs are set correct. RPM has been between 7500 & 7800. Using std oil pump and 20w-50 oil.
Any help into what is causing this or how I can fix the problem?
Thanks
Thanks
