Alternator mount
  • robdog98
    • Mar 2011
    • 53
    Alternator mount
    Anyone have and drawings for fabricating and Alternator mount for a Ford 2.3 ?
    Can't seem to locate anything on the net.
  • biggy72
    • Nov 2012
    • 17
    I found a cast mount off of an old courier, but I'd like to build something significantly lighter too.
    • car62
      • 1579
      here are a couple pictures for the small alternators
      www.raceidaho.com
      • miniman69
        • 58
        I have some of the early mustang alt mounts that were on manual steering cars, they are alum and mount on the dist sid of the motor [the three big holes] it is what I used for years can use any ford or aftermarket lw alt mine was just 6 lb 40.00 ea u pay shipping from Indiana
        • camarofever
          • Apr 2013
          • 85
          Been thinking about mounting an alternator to the rear end.
          • robdog98
            • Mar 2011
            • 53
            pictures?
            Do you have a pic of what they look like?
            • Profile
              • Jan 2009
              • 157
              A Merkur air condition mount works great, and puts the alternator on the passenger side. Bolts right up to the block.
              • crcltrakr
                • 293
                Not quite sure why you'd want to add any weight to the right front of a mustang.....
                JerryM
                • Wild Blue 32
                  • 90
                  What year Merkur?
                  • return to dirt
                    • 1008
                    Originally posted by Wild Blue 32 View Post
                    What year Merkur?
                    not sure where you are from but here in northern california there are not very many merkurs around although i have worked on some. the pictures that car62 showed are about the best i have seen. i run a small single wire alt on my pinto using a modified stock alt mount and wouldn't run without one again. the mount car62 shows looks nice and i will make one like that for my mustang.
                    olin
                    • car62
                      • 1579
                      Olin,you have to use a small diameter waterpump pulley,the 7" Esslinger wont clear,the one we used at the time was from raceeng,the new setup we are using the super light serpentine setup from cheaphp.com http://www.needhp.com/ford23serpenti...pulleykit.aspx
                      www.raceidaho.com
