Zero decked 30 over 2700 bottom and a high cc size head roller that's shaved to intake bolts arp studs 27 though cosmetic I need the proper way to install and torque specs 34 degrees timing cam straight leveled and octane to run cause 110 would sometimes stay running after off like bad gas just trying to get a idea if I am doing something wrong
proper way to install a high cc head on a zero decked block 2700
well i believe your ignition timing is too low,id probably start out at no less than 36 degrees.No matter how hard you try...you cant fix stupid!!!
www.raceidaho.com
Race engineering tech said same I was always told no more then 34 on 5.7 so maybe bump up and jet accord to keep kool still looking for octane 110 ok and 90 psi torque on arp studs ok?
thats not true,we have found great power in the 38-39 degree range...110 should be fine and yes 90lbsNo matter how hard you try...you cant fix stupid!!!
www.raceidaho.com
