What are the thoughts of mounting the left rear shock to the top of the bird cage on a 4/4 car . Basically it's attached to the left upper bar at the bird cage mounting point ,has anyone tried this?
shock mounting on left rear
I tried to upload a pic but no luck. I just added a longer bolt on the top of the bird cage (the one that the upper four bar is on ) I seen it on a GRT modified . Seems like it might work just wondering if any one liked it.
That pic he did that just messing around you would not want to mount the shock to the birdcage itself make a bracket and make it attach to the axle tube next to the birdcage is the proper way to do it... I currently have it on my car and it works well but it's all about having the correct shock valving
Probably stiffer because of the reduce shaft speed between axle tube mounting and BC mounted in front.
We have our shock mounted on top of the rear end at top of the birdcage. There is no difference if you know what you're doing. Nothing is different at all too or bottom if located in the same motion ratio location. It's this Leroy Washington bs that everyone see this cr@p at. It's a kid who made the (not a nice word)(not a nice word)(not a nice word)(not a nice word) page who has no friends.
This setup is kinda slick in the fact that is providing half of the damping in the x direction (front to back) and half in the y direction (up and down) assuming the shock is angled 60 degrees relative to the ground and the connection point on the chassis. In a linkage system you develop the most force on the system when your angle of transmission is 90 degrees relative to each other (in this case the top link relative to the shock which looks somewhere around 70 is degrees). What this means is that shock will be doing the most work in the x direction instead of the y direction. I would assume (just my opinion) the theory behind this setup is to help the car get up on the bar but dampen the bar motion rather than dampen the motion of the axle. Its almost like this setup is trying to perform the same task as a shock on the pullbar.Last edited by dkibel; 11-10-2016, 10:47 AM.
I know someone that is running a deal like this.
only been beat if he had a flat tire or broken axle since he put it on.I think there should be lifeguards in the genepool.
