shock mounting on left rear
  • dkibel
    • Sep 2015
    • 28
    I was trying to figure out the chain on the birdcage as well. Wouldn't having the two chains be redundant?
      • 14305
      He said it was in case a bar broke
      • Dirt_Buster
        • Jun 2016
        • 104
        We chain just the birdcage as we dont want the chain affecting rear end rotation with the pull bar.
        • dirtracer07x
          • Aug 2014
          • 101
          would this work on a bmod....3link setup?
          • Kromulous
            • 3008
            If you notice the inside axle tube chain is loose still, and the bird cage chain is tight.
            So this is telling me that there trying to pit the birdcage chain against the spring on the back of the birdcage. That should apply more and more pressure to the LR tire as he picks up the throttle, sort of like a Rumley device.
            The more the car trys to climb the bars, via the bar angle, the more it drives the LR into the ground, via the chain. Basicly using the chain to pivot against.
            Dam thats cool.
            Just say no...
            • GRT62
              • Jan 2014
              • 177
              Originally posted by Kromulous View Post
              If you notice the inside axle tube chain is loose still, and the bird cage chain is tight. So this is telling me that there trying to pit the birdcage chain against the spring on the back of the birdcage. That should apply more and more pressure to the LR tire as he picks up the throttle, sort of like a Rumley device.The more the car trys to climb the bars, via the bar angle, the more it drives the LR into the ground, via the chain. Basicly using the chain to pivot against.Dam thats cool.
              That is exactly what I was thinking when I first seen this photo.
              • mod88s
                • 226
                The chains is connected to the bottom of the birdcage where the lower link connects. How would this be working against the spring? Seems like it would travel the same way as the spring, working with the spring. thoughts?
                • MKD12a
                  • Feb 2009
                  • 49
                  With the chain connected to the floated birdcage there is no way this would fly in IMCA
