Bms #728
  • langdonracing48
    • Dec 2013
    • 183
    Bms #728
    I bought a 2011 BMS modified, chassis number 728. I was told it was a "challenger", but I've heard from others that they went to just building the dmr cars in 2010? Anybody know anything about these things?
  • TS3g
    • Oct 2007
    • 201
    If the front roll cage down bars are bent and go down to the main frame in one piece, it would be a DMR. They also had cross-shaft mount upper a-arms as well.
    The older BMSs before DMRs had split mount adjustable upper a-arms, and the front down bars were in two pieces, split by the cross bar.
    There are a lot of other differences as well, but those are easy ones to spot. This is all off of memory from seeing them though, so I may be wrong. I don't remember when they started building them either, but it was the year after Murray drove a Victory
    EDIT: I looked at some pictures and Murray had a DMR in 2010, so they were built then
    • dirtmod21
      • Jan 2012
      • 50
      If that is Aj Wards old car that is indeed a challenger. That was purchased originally by Holman. Then Stemler had it before Aj. That is a good car. The dmr cars have dmr welded on the chassis next to the chassis number.
      • langdonracing48
        • Dec 2013
        • 183
        It is aj wards old car.
        • langdonracing48
          • Dec 2013
          • 183
          Is there a way to verify it is a 2011? Does anyone have a number for BMS? I tried getting on there website a while back but it was down. I heard they were sold.
          • dirtmod21
            • Jan 2012
            • 50
            It is in fact a 2011. My old one was chassis 716 and it was built late 2010 but considered an 11. It was the intimadator tho.
            • dirtmod21
              • Jan 2012
              • 50
              Bms has been sold. First Class Chassis by Xtreme are the new owners. Not sure of a number but I know they are still building the BMS with a couple small changes. Best person to deal with for tech support is Joel Smith at Close racing. 8142253250. He has been very helpful for BMS guys in Michigan.
              • langdonracing48
                • Dec 2013
                • 183
                Thank you very much everyone!
                • racincowboy3
                  • Nov 2013
                  • 32
                  Jimmy Reeves is building the BMS cars not at Xtreme in Great Bend, KS. The shop number is (620) 796-2290. He will be able to help you out
                  • GavinHunyady187
                    • 31
                    my 2008 or 2009 was #608 so I think its reasonable that is an 11 or 12, I think I have a setup sheet for it if you need one... but that car was really fast, I wouldnt change a thing.
                    • langdonracing48
                      • Dec 2013
                      • 183
                      I drove it a couple of times, it was really unpredictable and hard to drive so i set it on the scales. Had 378# of bite in it lol. Aj sold it to another guy who sold it to me so I'm sure stuff was changed.
                      • KLAY-DOH
                        • Nov 2016
                        • 3
                        I just bought what I was told is a 2008 with frame number 538.
                        • KLAY-DOH
                          • Nov 2016
                          • 3
                          Any help with set up would be helpful, I'm turning this back to an A-mod from sport mod so bar lengths and such would be helpful!
                          • langdonracing48
                            • Dec 2013
                            • 183
                            I don't have the challenger setup sheet but I can forward you the dmr BMS setup sheet if you pm me your email address. Also, Ryan Sebo/Sebo Motorsports is a lot of help with BMS cars. Give him a call at 17017203889 as well as Joel Smith mentioned above.
                            • KLAY-DOH
                              • Nov 2016
                              • 3
                              sent PM thanks!
