We are having an issue of blowing oil out the valve cover breathers. We even ran a hose off the valve cover to a fill can with a breather on it and it's filling the can with oil and blowing oil out of that breather as well. We are having to add 2-3 quarts of oil throughout the night not to mention the mess. Any suggestions on how to fix this?
Blowing oil out of breathers
Check to see if the slits in the valve cover were the filer goes on have been opened up to let oil go into motor faster when oil is changed.
If not sounds like a lot of excessive blow by, crankcase pressure.
I race at one track that I have that problem, but only at the one track. Long straights, tight turns.I think there should be lifeguards in the genepool.
I'm a crew for 2imp. this motor has had this issue since it was new. It has the orig. spark plugs. we are thinking about trying the crankcase evac kit from day mtrsprts, that hooks to the headers. leakdown test sounds like a good idea before we go any further. thanks everyone.
I have one doing the same once it gets to speed. Compression is good, leak down is good, plugs are good. Was going to try different valve covers Sat. night but it rained out.
Let me add - motor has 62 laps around Devils Bowl, 20w50 Valvoline, alk for fuel. Total Seal conventional rings.Last edited by LateModel B23; 06-11-2017, 09:03 PM.
Many times (if the engine don't have excessive blow by thus excessive crankcase pressure) it's the breather system:
Too high a velocity of air coming out of breather area, this doesn't allow the oil droplets to drop out of the air before making it all the way out of the breather system. Think of it this way: You have air/oil droplet mixture in the crankcase volume, if the air is going 100MPH out the breather it won't un-suspend the oil from the air and take the oil out with the air. Now slow the air down to 10MPH and the oil will drop out of the air before it makes it out of the breather system.
People stick stuff in the breathers to try and separate the oil but are blocking or restricting the air movement and thus increasing the velocity of the air compounding the problem. I have seen too small a hole in the valve cover under the breather stand cause this and just opening the hole up to reduce the velocity can/does stop this.
Ideally you'd like a large diameter area and something reasonable tall that allows time for the weight of the oil to make it fall out of suspension and not come out with the air as the engine allows the crankcase pressure to escape.
Also make sure if your using an external breather that the line doesn't have a dip in it. Oil can accumulate in the line slowly at the dip and once it blocks the line the air will push the entire volume of oil out cause it's blocked by the puddle of oil in the dip in the line.
