I have a 2010 taylor chassis 4 link on both sides with a solid pull bar, with a ton of left rear I run on a very tight 1/4 mile track that always has bite in it it is rare tht is gets real slick. i Cannot seem to get the car to hook up good at all unless it has left front tire two foot in the air. what do i need to do? any help is greatly appreaciated
help please
Option 1. call taylor!!! he built the car and should know them inside and out
Option 2. post more info.
Option 3 with info you posted i can say take off solid pullbar replace with spring bar around 1400pds
springs- lf 600, rf 700, lr 175 rr 175 20 degrees of angle in both upper bars 9 degrees in left lower and 6 degrees in right lower shocks lf 6-2 rf 3-5 lr 6-2 rr 3-5 with about 100 bite in left rear
