help please
  • Wright Motorsports
    • May 2011
    • 2
    help please
    I have a 2010 taylor chassis 4 link on both sides with a solid pull bar, with a ton of left rear I run on a very tight 1/4 mile track that always has bite in it it is rare tht is gets real slick. i Cannot seem to get the car to hook up good at all unless it has left front tire two foot in the air. what do i need to do? any help is greatly appreaciated
  • powerslide
    • 2696
    Option 1. call taylor!!! he built the car and should know them inside and out
    Option 2. post more info.
    Option 3 with info you posted i can say take off solid pullbar replace with spring bar around 1400pds
      • May 2011
      • 2
      springs- lf 600, rf 700, lr 175 rr 175 20 degrees of angle in both upper bars 9 degrees in left lower and 6 degrees in right lower shocks lf 6-2 rf 3-5 lr 6-2 rr 3-5 with about 100 bite in left rear
      • racin6mod
        • 2172
        again take off the solid bar thats your forward bite problem and then take a second look at the r side bars angles seems both have to much angle in them. lr spring is soft is it on the bird cage in front of the axle tube.
