How much rake do you want typically in a modified? 4 bar 4 bar. And what does raising it up and down on the frame side do?
J bar rake?
Starting Point:
Start with pinion end at:
Ford 9" - Center Line of Pinion
QC - 1 1/4" to 1 1/2" above pinion center line.
Then set rake so left hand frame end is 7" higher than pinion end. Measure from center of attaching bolt to center of attaching bolt.
Adjust as needed from there.Last edited by BigBlueFord; 05-21-2011, 10:24 AM.Crewchief #21 Modified Hansen Motorsports 2014 GRT by Phillips IMCA Modified
