J bar rake?
  • Hagen14t
    • May 2011
    • 167
    J bar rake?
    How much rake do you want typically in a modified? 4 bar 4 bar. And what does raising it up and down on the frame side do?
  • BigBlueFord
    • 189
    Starting Point:
    Start with pinion end at:
    Ford 9" - Center Line of Pinion
    QC - 1 1/4" to 1 1/2" above pinion center line.
    Then set rake so left hand frame end is 7" higher than pinion end. Measure from center of attaching bolt to center of attaching bolt.
    Adjust as needed from there.
    Crewchief #21 Modified Hansen Motorsports 2014 GRT by Phillips IMCA Modified
    • Graff Spee
      • 881
      Yup!! Listen to big blue!
      • ThrowInDirt
        • 27
        raise it for less body roll or lower it for more body roll
        • dirttrackrocker
          • Nov 2010
          • 664
          Raise it on Frame side for less body roll??
          • 28m
            • Dec 2010
            • 49
            Yup. Acts like a kickstand on a bicycle with more angle.
            http://s200.photobucket.com/albums/a...8m%20and%201m/
            • romeropolo
              • Feb 2010
              • 24
              I am not seeing how this works......can you give some more details on this???
