Terrible push getting in
  • dirttrackrocker
    • Nov 2010
    • 664
    Heres what I have. I have an older 2002-2003 GRT Metric 4 bar LR swingarm RR
    Springs
    LF 700 RF 750
    LR 200 RR 275 0n the swing arm
    Shocks
    LF 5/3 RF 3/7
    LR 5/3 RR 35 LR Spring behind shock in front RR spring and shock on Swing arm
    51.1% Left
    57% Rear
    40 lbs bite in LR
    J bar even with pinion and 7" rake
    Leading LR by 1/4
    LR top bar 23% Bottom Bar 10%
    The car has a terrible push getting in the corner. The only way I can turn it is to let off the gas and stab the throttle, if I touch the brakes it wont turn at all. I turned the right front off (even though were not allowed to) to try to cure this and it helped a little but not much.
    Any suggestions on how to loosen it up getting in??
  • washeduptoo
    • 1353
    Where is you jbar on the pinion?
    • dirttrackrocker
      • Nov 2010
      • 664
      Even with pinion..
      • washeduptoo
        • 1353
        Have you tried lowering the rake in jbar or up above pinion, I'm guessing its a 9in rear end? What about raising the rr bar on frame? I just saw in your 1st post you said even with pinion, sorry.
        • dirttrackrocker
          • Nov 2010
          • 664
          Haven't tried that. What will that do?? Sorry, I'm new to these cars.
          • dualdj1
            • Jun 2009
            • 654
            Generally speaking when a car doesn't turn in, lower RR bar for more rear steer (will loosen off as well), add rear stagger, soften LF spring, stiffen RF spring.
            It sounds like you've got too much drive, which comes from rear % and bar settings. So you can lower rear % if possible, or if you want to keep it then soften up that LF spring and add stagger/lower RR bar.
            Being a 4 bar LR though, you may have your 4 bar settings off which is creating too much drive, and I can't help with the 4 bar adjustments.
            • dirttrackrocker
              • Nov 2010
              • 664
              Well, not sure how it could be too much drive. I'm talking about totally off the gas and on the brake. I've got it dialed all the way to the rear (brakes). My buddy says it doesn't look like the car is transfering weight to right front.
              • 1cln_sdime
                • Apr 2008
                • 138
                What r your wheels weights?
                • dirttrackrocker
                  • Nov 2010
                  • 664
                  LF 539 RF 519
                  LR 709 RR 660
                  Im at work now the rears I know are true, I'm pretty close on the fronts.
                  • washeduptoo
                    • 1353
                    Try lowering the jbar on the frame an inch and see how you like it, it will lower your roll center. Sometimes you can get too much rake and not let the car work properly, you have to find what rake works best for your car/driver/track.
                    • dirttrackrocker
                      • Nov 2010
                      • 664
                      Thanks I will try that..
                      • dualdj1
                        • Jun 2009
                        • 654
                        Yeah drive was not the right term i was looking for, but the adjustments I listed should still be correct for your condition. RR bar, stagger, LF spring. Jbar rake as mentioned will help too.
                        how did you decide on your front spring rates? Did they just come with the car that way?
                        GRT setup sheet:
                        LF 550 RF 600
                        LR 225 RR 225
                        also for your reference:
                        • dirttrackrocker
                          • Nov 2010
                          • 664
                          Thats what was in it when I bought it. The spring rates you have are for a Chevelle clip. I have a metric clip. Just found a set up sheet for older metric cars and it says springs should be 750 LF and 850 RF. I think I'll try that.
                          • dualdj1
                            • Jun 2009
                            • 654
                            cool deal, that's all i could find but was guessing it wasn't correct. their setup adjustment sheet will still hold true with your changes though, so know as you go stiffer RF you'll tighten exit as well. LF will only effect entry. So if you're happy with the way it's coming out of the corner, I'd just soften the LF, OR adjustyour j-bar.
                            • dirttrackrocker
                              • Nov 2010
                              • 664
                              cool, thanks...
