Birdcage Question
  • OWM50
    • Mar 2009
    • 42
    Birdcage Question
    When bolting together birdcages, what is that gap you should have instead of having them bolted tightly together?
  • washeduptoo
    • 1353
    Are you talking about the retaining rings against the b/c?
    • sj valley dave
      • 1016
      OWM50, as washeduptoo asked, are you talking about the retaining rings that keep the B/C located on the axle, or are you talking about the actual 3 piece B/C?
      • OWM50
        • Mar 2009
        • 42
        Im talking about the nylon retaining ring between the pieces of the birdcage.
        • xxxmod
          • Jan 2012
          • 111
          BSB send a nylon ring that goes between the birdgage and the retainer ring on some of their stuff,no gap make sure its tight.
          • LM14
            • 490
            What kind of birdcage? Bearing or liner or steel? What brand? There are a lot of options and the correct answer depends on the style/brand.
            SPark
            • OWM50
              • Mar 2009
              • 42
              They are TWM steel birdcages, I honestly have no idea what kind of mechanism they roll on because I havent had them apart. I took the rear end out this winter to have the chassis painted and noticed that the bolts were loosened up a bunch and was told that there was suppose to be so much tolerance between the nylon pieces.
              • hotrod4890
                • 120
                Call Kenny or Sam at TWM and they should be able to help. (318)640-4112
                • LM14
                  • 490
                  Is there a grease zerk on your birdcage body? If so it's a liner style or metal on metal and it needs about the thickness of one of the nylon pieces for clearance between the birdcage and clamp. Set your outside clamp so the birdcage puts the bars are where you want them and pet the clearance to the inside clamp.
                  If there are no zerks it's a bearing style cage, I would suggest locating off the bearing races like BSB does so there is no friction against the body sides.
                  These load the sides of the races and really frees things up.
                  JMO,
                  SPark
                  • OWM50
                    • Mar 2009
                    • 42
                    yes thes have grease zerks on the body and basically i need to snug them up to the nylon rings?
                    • dirttrackrocker
                      • Nov 2010
                      • 664
                      Yes, but make sure you can still rotate them by hand.
                      • powerslide
                        • 2696
                        you will need to grease each week. I would suggest taking them off and cleaning the tube and birdcage every 4-5weeks. If money allows at some point i would get the bearing birdcages if for no other reason than they are less maintence.
