'08 Shaw short panhard vs. 22" J-bar
  • 72RACIN
    • 61
    I have an '08 Shaw 4 bar car. Am now ( and always have been ) running the standard 22" J-bar and am wondering if anyone is running the shorter straight panhard bar off the left side of the pinion? Car is pretty good on the tacky track but is lacking on the slick. On all my other cars, I have run the short bar and liked the drive they had.
    Right now, if the car is good and ballanced through the corner, I have no drive. If I give it the drive I want, it's too loose in... If I tighten entry, it's lose out.
    My thought is to use a 15" (ish) short bar going to the outside of the j-bar mount, but I am worried that the car will then be too tight.
    Any thoughts?
  • 72RACIN
    • 61
    Anyone? Am going out with the straight bar this weekend, just wanting to know what to expect. Don't know what kind of split/angle to start with.
    • dirtracr33
      • 278
      sounds alot like our '08...try it but i probably wouldn't get carried away with alot of rake, maybe 2-3 inches...maybe k.shaw can give you a better answer....post your results, i'd like to know how it goes..good luck.
      powerslave
      • Dirtrunner35
        • May 2010
        • 632
        How are you giving it drive ?
        • 72RACIN
          • 61
          Adding drive with added LR mainly. Can't add any more angle to LR upper.
          • Dirtrunner35
            • May 2010
            • 632
            Springs, tire pressures and shocks ?Throttle control on slick.Too much pre load in pull bar spring ? Take out rear steer on slick.
            • washeduptoo
              • 1353
              Do you have some holes closer to the axle on b/c on lrt or on bottom of b/c that further from axle? If your track usually gets rough, be careful on running that straight bar. You might loose some side bite also with that bar but should be tighter on throttle. We ran 4.5 inchs of rake with a 12 inch bar but this wasn't a Shaw. Best of luck.
              • 72RACIN
                • 61
                Lru in bottom hole on bird cage also. Track stays pretty smooth. I'll see what happens tomorrow. Thanks
                • Dirtrunner35
                  • May 2010
                  • 632
                  Go up one hole on lru
                  • 72RACIN
                    • 61
                    Went out with the shorter panhard this weekend. Car was a lot better on entry and through the middle, but felt like i had less drive out. Going to index the LR birdcage and add some angle to the LRU. Any other suggestions to keep the car good in and through but add more drive out?
                    • Dirtrunner35
                      • May 2010
                      • 632
                      How is your rear bars set now, tire pressures ? Did you check your tire temps.
                      • 72RACIN
                        • 61
                        Here you go....
                        At ride height- On Jack stands (full drop both sides)-
                        LRU-24* 44*
                        LRL-7* 28*
                        RRU-19* 35*
                        RRL-5* 20*
                        Pull bar(short)-20* bottom hole, centered
                        Panhard-16* 15" long 4" rake
                        Tire pressure(KK704,Shaw recommended)-LF 11, RF-13, LR-8, RR-12
                        Shocks- T-Bone set
                        Before the race had 15# LR, after hot laps didn't like how low the LR was, added 5 rounds...guessing at about 45-50# LR now.
                        Birdcages-BSB bearing - LRU-middle hole RRU-top hole
                        Now that I think of it, good in.. little loose in middle... lot loose out.
                        Track was very smooth and slick
                        Medium/high banked 1/4 mile
                        • washeduptoo
                          • 1353
                          You have any lead/trail in rr? What offset on lr, moving it out will add some drive, what about springs and pull bar? Dampner shock on rear end, oil or gas?
                          • 72RACIN
                            • 61
                            1/4" RR trail. 2 offs all the way around, 3 off RR. Oil 90-10 shock. Springs....lf-600 rf-650 lr-175 rr-175.
                            Thanks
                            • 72RACIN
                              • 61
                              Pull bar- Shaw 600-2000 progressive
                              Left - 52.7%
                              Rear- 55.5%
