'08 Shaw short panhard vs. 22" J-bar
  • washeduptoo
    • 1353
    Take the trail out of rr to see if that will help. How much preload in the spring? You could take the dampner shock off and that would probably help but its going to loosen entry some. Have you had a chance to talk to Kevin about this?
    • Hagen14t
      • May 2011
      • 167
      Try and swap the front springs around. It will tighten entry some and then maybe bring up the rear percent a little. Just some suggestions. Good luck!
      • 72RACIN
        • 61
        I have talked to Kevin a lot in the past...he helped out a lot. My original post was for switching to the straight panhard bar, where they want the j-bar to be used. I ran the panhard this weekend and liked it...just looking for some more ideas now to get more bite.
        I am running 1/4"RR preload in the pull bar.
        • washeduptoo
          • 1353
          Try running no preload on that spring to see if it makes a difference, then later try a 1/2 preload. Is your pull bar mounted forward/centered/or behind center line of axle? Running rr even with lr helped us on slick. Good luck
          • 72RACIN
            • 61
            I don' t know where the "RR" on the preload came drom on my last post? I do run the pull bar centered. I indexed the LR birdcage (2 rounds in top, 2 rounds out of bottom) to see how much that will help.
            what is your experience with lowerong the LR lower? I don't want to change entry...just middle out.
